Hitachi 42xt42u (17ips20) backlights
  • compcycle
    • Aug 2013
    • 32
    • uk
    Hi I have the above tv, came in with no backlights at all. Replaced 17IPS20, now I have backlights for about 3 mins. Monitered voltage to panel, I get a slight variation between 159 and 161 volts, occationaly dropping to 156 at which point the screen flickers. does this 2 or 3 times then screen goes out, voltage to 0.00
    Any ideas? Not sure about the replacement board, was a pull from a smashed tv.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Hitachi 42xt42u (17ips20) backlights
    Sounds like your new Psu is faulty, or you have an intermittent connection in the Led strips. This uses the great VES420 panel and I have had the Leds in the screen the connections between them break down. Maybe try heating the Psu see if it shuts off faster ? Or try moving the Tv about see if it stays on longer.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Also wait what size was the smashed one ? You cant just use any old IPS20 you need the exact one for the 42" VES420 as the smaller or bigger ones have more Leds so bigger drive voltage or less Leds so less drive voltage, the Psu might not be able to supply the current for them all. You must use one from another 42" exactly.
      • compcycle
        • Aug 2013
        • 32
        • uk
        you might have hit the nail on the head, i have no idea what the ips originally came out of, but i think its only seen in tvs 40 and above, i might be wrong. ill see if i have any more. the original supply had no backlights at all, so where would i start looking at that one for faults?
        • flocko
          • Nov 2012
          • 1121
          • uk
          You need to match the part numbers from you old to the new board? on the 17IPS20 there are over forty part number that cover this board look at the white bar code sticker 23XXXXXX and match that
          • compcycle
            • Aug 2013
            • 32
            • uk
            ok they dont match, so we have established that the replacement board is not suitable. So the next step is repair the existing board? What commonly fails on these to cause no backlight?
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Normally the Led controller or the mosfet or the diode. Also possibly the switching transistor for the 24v rail. Quite tricky to find. Will explain more later when im home.
              • flocko
                • Nov 2012
                • 1121
                • uk
                I have a repair kit (eBay item 26245489602 )to fix the no back light, replacement parts for the mosfet Q502 and four string LED driver IC U500, you would need to check for your self if these are your problem, and not an open LED in the strings ? if you are not going to return the board with the wrong part number you could change the parts on to your faulty board with the ones on there ?
                • compcycle
                  • Aug 2013
                  • 32
                  • uk
                  thanks, just ordered the repair kit from ohm supplies!
                  the board with the wrong part number is mine anyway, just found another one as well, this one shows splash screen then turns off, so pretty sure its not the leds.
                  • compcycle
                    • Aug 2013
                    • 32
                    • uk
                    and that item number is invalid?
                    • flocko
                      • Nov 2012
                      • 1121
                      • uk
                      eBay item number:262454589602 missed out a 5 out , the screen can flash on with an LED open for a sec or two. but that string will show no load to the driver and the driver will shut all four strings down. Andy (ohm supplies)will be pleased with the order
                      • compcycle
                        • Aug 2013
                        • 32
                        • uk
                        understand that, but on the second ips the tv was staying on for 3 to 5 minutes, surely wouldnt do that with a duff led?
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Controller possibly shutting down.
                          • flocko
                            • Nov 2012
                            • 1121
                            • uk
                            As I have said there are loads of versions of this board all running LED output voltages to match the number of LEDs that are fitted and the number of strings that are being driven, you could have blown what could have been good LEDs by fitting a supply that is running to high an output.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Agree Flocko when Leds get too hot and are about to burn they flicker.
                              • compcycle
                                • Aug 2013
                                • 32
                                • uk
                                Thank you for the pointers, I swapped the string driver IC (U500) off the replacement board on to the original, and it seems to have done the trick, on test now for half hour so far so good
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  Yay, now factory reset the Tv and then set the menu to dynamic and turn the backlight to low.
                                  • compcycle
                                    • Aug 2013
                                    • 32
                                    • uk
                                    ok will do, reason?
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Well have you not heard of the Led failure epidemic in Tv's ?
                                      • compcycle
                                        • Aug 2013
                                        • 32
                                        • uk
                                        yes mate, lol the obvious reason! Just wondered if it was to do with the ic change!
                                        • Jaime Morillo
                                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                          by Jaime Morillo
                                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                          The TV was stuck on the logo and I couldn't access the update menu.
                                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                          The image result was good, but the image is inverted.
                                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                          08-18-2025, 11:38 AM
                                        • max789
                                          Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                                          by max789
                                          Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                                          I made the following tests:
                                          1. Disconnected the main board from Power Board = backlight works.
                                          2. Connected the main board and disconnected the T-Con = backlights does not work.
                                          So I ordered a main board from Ebay also BN41-02156A but from...
                                          01-18-2024, 06:56 AM
                                        • bpcannan
                                          VIZIO M557-G0: Backlights or ???
                                          by bpcannan
                                          'Morning,
                                          I get sound and picture when powering on the TV and its stays that EXCEPT that the left half of the screen will dim every few seconds then return to normal while the right side of the screen performs as designed.
                                          Did the soft and hard reset options pulling the plug, using the reet option in the vizio menu to no avail.
                                          I checked the mainboard - found some popped capacitors so replaced it - but that did not change the situation.
                                          I checked the t-con board. It is getting good power. Then I removed one ribbon cable to see if I could isolate...
                                          10-29-2023, 06:36 AM
                                        • jesterace
                                          Samsung UE49MU6400 acts dead until disconnecting backlights, then works.
                                          by jesterace
                                          Hi everyone I have this TV which was dead one day when I tried to turn it on. I've had the cover off and there was just a pulsating/electrical clicking/ticking noise from the PSU. I disconnected the mainboard as sometimes this works to just fire it up with backlights on? That didn't help. Same noise. Then I disconnected the backlight cable from the PSU and the TV came alive. It appeared to respond to the remote and i'm pretty sure it's fully operational when there is no backlight connected.
                                          However, I am in a dilemma.
                                          I tested the backlight outputs with the lights disconnected...
                                          10-20-2024, 10:15 AM
                                        • wolf1976
                                          hitachi 50hk5600 problem with display
                                          by wolf1976
                                          hi
                                          i have the above tv and the display starts distorts the display at only in applications like you tube
                                          after and on the didital channels
                                          now without connect the antenna only the image of itsselfs tv i have the image i have in attach
                                          i have read in another forum someone else with similar problem with mine changes tcon card and motherboard and the problem remains
                                          can you tell me someone what is the reason that can causes that problem ? is the same the sisplay ?...
                                          09-13-2025, 02:26 PM
