Samsung LNT4032H BN044-00134A No Back Lights
  • culcuhain
    • May 2016
    • 186
    • U$@
    Good morning!
    I am working on a Samsung LNT4032H TV with the power board BN044-00134A Power/Inverter Board.
    The will turn on, have audio and video is displayed on the screen when shown with a flashlight. The backlights do not come on.
    The voltages to the main board were within Spec. ALL the caps, including the 220uf 450v have been replaced with Panosonic or Nichicon (I don't use cheap parts) QI801 and QI802 (FQPF11N50CF) where both toast. QP801 (SPW12N50C3) was toast as well (tested those on my parts tester). All have been replaced. Resistors all have continuity.
    Here are some noted voltages while I check a few components last night (Black plug of DMM was grounded to chassis)
    DP801 55v/325v
    RP804 -55v
    BI801 325v/325v
    FI801 325v
    DI801 325v/325
    DI814 -40v
    That is all that I had time to check before it got too late.
    Any ideas on my next steps?
    Re: Samsung LNT4032H BN044-00134A No Back Lights
    Are you testing those Voltages on the HOT PRIMARY side of the circuit? If you are, then you are using the wrong GND ref. for your meter, that is why those readings are showing Negative number and wrong levels.
    When making the measurement in the HOT PRIMARY side, you HAVE TO USE the negative leg of the main filter cap as the GND ref for your meter, when working on the COLD SECONDARY side you can use the Chassis GND as the GND REF. for your meter.
    We also need good clear pictures of the top and the bottom side of YOUR board and the pictures of the whole back side of the TV that shows all the boards.
    • culcuhain
      • May 2016
      • 186
      • U$@
      Yes. I was testing the hot side of the circuit. I will solder a wire to the bottom of the main cap to make it easier to access when I test it tonight. I will post some pics up after I get home. Thank you for the quick response!
        The diagram attached my not be 100% accurate.
        The IC driving the QI801/802 may also be damaged when those MOSFETs shorted out.
        Pictures provided by shopjimmy.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Broken solder joint on the inverter transformer is common on these boards.
          • culcuhain
            • May 2016
            • 186
            • U$@
            Thank you. That is the correct PSU/Inverter board and Schematic. I have ordered a few of those IC chips and should have them Saturday. I will check the inverter transformer solder spots and just reflow them. I will report back sometime over this weekend. Again, thank you!!
            • culcuhain
              • May 2016
              • 186
              • U$@
              Ok. The parts came in yesterday and while the kiddo napped I went to work. i tested the Mosfets, Diodes, Bridge Recifier and resitors that I could. I reflowed the solder on the Inverter too... Looks like a bad FAN7382 chip from when QI801 and QI802 (FQPF11N50CF) shorted out. She has been up and running for about an hour with no issues... My friend heard what I was doing and dropped off his tv for repair... That is another thread....
              Thank you all for all the help! My patio will now have a tv!!!
                Thanks for the follow-up on the repair.
                • culcuhain
                  • May 2016
                  • 186
                  • U$@
                  and no more backlights. Going to tear into her this weekend.
                  • culcuhain
                    • May 2016
                    • 186
                    • U$@
                    Okay this is pretty weird. Reflow the solder on the transformer for the inverter. That had no effect. I checked all the diodes in the inverter section in line. They all tested okay. I pulled the MOSFETs and diodes can my test read them all good. I went ahead and replace the IC that I replaced before. When I plug it all in and tested it. And now I have back lights. Either the IC chip failed or I had some bad soldering on the board. I have the TV running in the garage right now. I'm going to run her 24 hours and see if all is well. I will also check temps about the power board and inverter board.
                      09-07-2024, 05:50 AM
                      09-06-2024, 11:40 PM
                      09-06-2024, 08:40 PM
                      Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                      This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-06-2024, 06:20 PM
