samsung un65hu7250f turns on no backlight
  • nwcs
    • Dec 2015
    • 311
    • usa
    This came in originally the customer said that he turned it on and the screen flashed but no picture. I turned it on and got backlight no picture and found it would not turn off. Checked the fuses on the Tcon and found F2 7a/125v was open, replaced with a 7a 125v fuse and it did not open but now I have no backlights unless I disconnect CNM803 from main. Voltages on CNM803 are as follows
    5 .9v 11 thru 15 13v 21 5v 8 thru 16 are 13v 22 is 5v and 24 is 3.5v all others are 0v. CNL802 2 thru 10 are 126v 3 thru 7 are 8v and the rest are 0v. I am thinking the main board may have taken out the tcon so I need both but would like some input before I tell the customer.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: samsung un65hu7250f turns on no backlight
    As you get Bl with Mb unplugged that means the Psu, Led driver and Leds and working ok. Likely your Mb is failed here, possibly got hit with a surge as the fuse blew as well and they dont randomly blow.
    • nwcs
      • Dec 2015
      • 311
      • usa
      That is exactly what I am thinking. At least the parts are cheap.
        09-07-2024, 05:50 AM
      • Egidio85
        Samsung UE55F8000SZ Turns on and off immediately
        by Egidio85
        good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
        This defect happens continuously, hearing the classic click of the relay every time.
        Power supply board BN44-00636B
        disconnecting the mains and lamps from the power board always causes the same problem.
        Is it normal that without anything connected this power supply turns on and off cyclically?
        any suggestions on what to check?
        thanks in advance
        03-11-2025, 12:45 PM
        09-06-2024, 11:40 PM
        09-06-2024, 08:40 PM
