Corrosion on Panasinic LED 55ET5
  • vz56098
    • Feb 2015
    • 14
    • Israel
    I have a corrosion on the bottom right and bottom center boards due to water that were stored there due to wrong way of cleaning the screen.
    Panasonic didn't want to repair it so I tried myself.
    The symptoms were vertical lines all over the screen.
    I cleaned all corrosion from the boards and now nothing is shown on the screen, including the menu (I can see that the monitor is turned on).
    What can I do next? Any recommendations?
    Thanks,
    Gil
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Corrosion on Panasinic LED 55ET5
    Could you supply some photo's so that someone could help you.
    • vz56098
      • Feb 2015
      • 14
      • Israel
      Photos of the screen or the boards?
      On the screen nothing is shown now (gray, but it looks like its turned on)
      The boards are clean now but before i cleaned i saw the corrosion on the components.
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        The boards please.
        • vz56098
          • Feb 2015
          • 14
          • Israel
          Ok, i will take some photos on Sunday as the TV is at my work now.
          Meantime any suggestions until then are more than welcome.
          Thanks a lot,
          Gil
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            It's extremely possible that the water has damaged the connections to the circuit board attached to the panel and may well be unrepairable. But without seeing the photo's I cannot be sure.
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • kdaniel
              Hitachi 58HK6100U - Horizontal Lines (Bottom third of the screen)
              by kdaniel
              As stated by the person I collected the TV from, it just stopped working overnight. However, I still gave it a go to try and repair it.
              There is a thread on the same TV but with slightly different issues where they had to tape connection points on the ribbon cable, so I want to see if this is repairable by any chance.
              After bringing it home and plugging it in, the TV turned on with its backlight working but had no picture. After removing the back cover, the first thing I tried is to unplug one of the ribbon cables and the situation is as follows.
              Left...
              11-16-2022, 09:23 AM
            • smic717394
              by smic717394
              07-25-2024, 10:16 AM
            • dicky96
              Laptop Screen top part working bottom part all white
              by dicky96
              Hi guys, I have an old laptop here I'm just trying to fix for the fun of it really
              The top part, maybe 25% or 33% of the screen display works, (DOS boot text or bios screen, I have no HDD fitted) but the bottom part is all white.
              On an external monitor connected to the VGA the picture is good.
              So basically I have a horizontal division, below which the screen is all white. There is no apparent damage to the screen or any vertical lines
              I tried cleaning the pins on the LVDS connector plug/socket as thy looked a bit dirty (18 pins plus...
              07-20-2022, 08:58 AM
            • Chrissygizmo
              by Chrissygizmo
              02-10-2025, 12:33 AM
