Trouble with Emerson LC407EM1
  • Josh04217
    • May 2016
    Hi, I have an LC497EM1 that will power on, then display "Digital Television" then go black.
    I removed the main board and discovered 8 bad caps so far.
    I have a multi tester, some soldering skills and tools, a variable power supply.
    I've repaired a few tv's and other things, either by replacing boards or by replacing capacitors and a couple diodes. I know how to test diodes and capacitors, sort of grasping transistors and resistors. I guess I'm just wondering if anyone has seen this before, and if it's indicative of worse than a few bad caps. Cheapest I can find the board is for 70, so it's worth 20-30 in parts and a couple hours to me, otherwise buying the board and throwing it together in 5 minutes sounds attractive.
    Would appreciate any ideas or input, thanks in advance.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Trouble with Emerson LC407EM1
    Have you looked at the screen with a torch to see if there is an image on it as you press menu to see if it's just the backlights switching off.
    Have you measured the voltages going to the leds?
    Some nice sharp pictures would help.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      I think there may be a circuit diagram for the set in a previous thread
      Edit:
      I'm not 100% sure but is this the schematic for your set.
      https://www.badcaps.net/forum/showpo...7&postcount=17
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8327
        Shine a flashlight into the screen. I wonder if the TV actually keeps on running and just the backlight turns off. I would look at the inverter board and check those transformers to be within 3% tolerance.
        • Dvsr
          On M-Audio AV40 active studio speaker's two zener diodes get really hot.
          by Dvsr
          Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
          I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
          After replacing the caps I started testing out the speaker. It seemed...
          09-10-2025, 10:20 AM
        • caspian
          What Zener Diodes on a Linear Power Supply
          by caspian
          Dear members,
          I have a linear variable power supply with unknown brand name that I used for voltage injection.
          Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
          In addition, I discovered that its zener diodes are defective.
          I can replace the burned transistors.
          But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
          Therefore, I cannot replace the zener diodes.
          I do not want to test the zener diodes in a test circuit to discover their model or value.
          no schematics are available...
          05-26-2025, 12:38 PM
        • Nikolai Danylchyk
          Lenovo T480s usb-c charging port replacement - Knocked off a couple of diodes.
          by Nikolai Danylchyk
          Hi folks. As the title says, I was doing a port replacement on a Lenovo Thinkpad T480s and in the process of post-solder cleaning, I somehow knocked off 2 or 3 diodes (i think they are diodes) near the main usb-c. I can't seem to find what kind of a diode is that. I know it's ultra tiny and just has a letter "G" on it. Would someone maybe have a proper schematic for the t480s model? I can only find the non-s one and it's quite different to the "s". Would love to figure out what component that is.
          Thanks in advance!...
          05-08-2025, 06:18 AM
        • Fontana
          BN44-00505A dead. Need to know voltages on output diodes (Samsung T22B300EW)
          by Fontana
          1. g´day! I have a samsung 22" tv monitor to fix. power supply model bn44-00505A. some stuff blown up on the primary, according to research something typical on this model. secondary seems ok. writings on the board say in outputs a5v (standby), b5v (switched) both on the lower 3 diodes on the picture, vamp and b13v (12.8v, both are the linked at the connector that goes to the main board) my question is, are both the upper diodes for 13v? I believe so but wanted to make sure before injecting voltage there to test. I injected 5v on the lower side and standby circuit is working fine
          2. if
          12-18-2023, 05:45 AM
        • DjKrish
          Zener diodes component equivalents
          by DjKrish
          Hey guys, i have a sony home theater power supply thats a few smd zener diodes blown but its so hard to get them. any recommendation for me to use normal zener diodes?
          1. UDZSTE-1710B (9.99V 5mA) (SC-90, SOD-323F)
          2. UDZSTE-1724B (24V 200mW) (SC-90, SOD-323F)
          3. UDZSTE-175.1B (5.1 V 200 mW) (SC-90, SOD-323F)
          These are the diodes. If i use normal zener diodes, it will work right? Question is, can i get these values on normal zener diodes?
          08-15-2021, 11:06 PM
