Samsung TV no display but has sound
  • Rodville
    • Sep 2015
    • 20
    I can not find a model number on the back panel but inside there is the model s50hw-xb03 on a sticker on the screen.
    I got this free because I was told there is a "bad fuse or something" and it should be an "easy fix". That said I have tested the fuses on the board and none are bad. When first plugged in there is a blue light by the power button. The light flashes with any remote signal. I plugged in a DVD player and got nothing. I happened to press the power button and the blue light went off and there was audio from the DVD but only in the right channel. The volume works and the source button stop the audio until I press COMP on the remote. I have the DVD plugged into the composite connector. With the blue light off there are two green LEDs on the one board that are lit up. I can not find anything on the model number s50hw-xb03 but a link back to this forum. So I am not sure if this is the TV model number or what. I was told it was a 55" TV but I don't think it is with the 50 in the model number.
    I took a pic of the back and a vid if what happens when on.
    http://vidmg.photobucket.com/albums/...psa0e7qzdb.mp4
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Samsung TV no display but has sound
    Owners saying a fix is easy fix is never an easy fix lets get that clear for a start lol. In a dark room with the Tv on does the screen appear to glow like a lit up grey ?
    • Rodville
      • Sep 2015
      • 20
      I will be able to check that later it's currently in a room that has a sliding glass door and I can't move it alone.
      • Rodville
        • Sep 2015
        • 20
        Checked it last night no light no glow no nothing.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Do you have all the voltages given, as written on the label attached to the panel?
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Common issue with these is the Ymain 8 small Zener didoes tend to blow causing no picture. Start off by checking the Vs voltage from the Psu. Then the voltage on both sides of the fuses on the Sus boards.
            • kca
              Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
              by kca
              Hello all ~
              I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
              This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
              No picture. No sound.
              I tested all the voltages coming out of the power supply...
              10-12-2023, 05:23 PM
            • slimsoul
              Samsung TV`s UE32J5500AK and UE48H6400AK Red Standby Light - No Picture/Sound
              by slimsoul
              Hi, I'm new here and looking for some advice on how to diagnose an issue i have with 2 samsung TVs.
              I have a UE32J5500AK and a UE48H6400AK both with the same issue of red light but nothing happening on the screen, the red light responds to remote or button press by flashing once but stays red. I have searched forums but most turn up a blinking red light.
              I have tried replaceing the power board on the UE32J5500AK last year but this resulted in the same outcome.
              The UE48H6400AK recently developed some small bright areas on the screen, then last week would not power...
              03-12-2024, 03:55 AM
              09-07-2024, 05:50 AM
            • mar1in
              Samsung TU8000, backlight and sound on, stuck in blue screen
              by mar1in
              I've got this Samsung here that would be stuck in a boot loop.
              After opening up and doing the tape block method, I was able to get it to turn on and play sound from the HDMI input, but with a blue screen.
              Does that mean there is another combination of pins that I need to block in order to get a picture, or is there something more serious, faulty mainboard or faulty panel?
              Thanks in advance
              11-08-2023, 05:43 PM
            • MOSSEP
              Monitor Audio RSW12 - Green light, but no sound
              by MOSSEP
              Hi
              Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
              Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
              The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
              I have already tried replacing all of the...
              01-26-2025, 08:33 AM
