Old Samsung LCD
  • n01d3x
    • May 2016
    • 8
    Old Samsung LCD
    I am trying to repair an old samsung lcd, board
    BN44-00264A. I followed the steps I found herehttps://www.badcaps.net/forum/showth...t=26568&page=2
    Continuity on all points of the rectifier are ok except for 2&3. All caps look ok visually, I assume its either the rectifier or a mosfet, thoughts. Oh, originally it turned off and wouldn't turn back on, no stand by or nothing. The main fuse was blown and blew a new fuse immediately.
  • n01d3x
    • May 2016
    • 8
    Re: Old Samsung LCD
    I tried to edit the topic to include the model info, but for some reason it doesn't show up in the title. Here is the info, Samsung LCD LN40B640R3F Power Board BN44-0026A
      Re: Old Samsung LCD
      Can we see the straight shot pictures of YOUR board top side and bottom side?
      • n01d3x
        • May 2016
        • 8
        Re: Old Samsung LCD
        I'm at work, but I'll take some pics when I get home, thanks!
        • n01d3x
          • May 2016
          • 8
          Re: Old Samsung LCD
          Best pics I could get, if you need better I can get a better camera later and take better ones. It's the same board as the one in the link I posted. You gave the guy in that post a list a points to test on his rectifier, I did the same and got in the 50 range with the 200 setting on everything except point 2 & 3 I got nothing.
          • n01d3x
            • May 2016
            • 8
            Re: Old Samsung LCD
            Bump for help. I guess i could just ohm out all of the mosfets and caps, replace any bad ones as well as the rectifier?
            • n01d3x
              • May 2016
              • 8
              Re: Old Samsung LCD
              One last bump before I give up
                Re: Old Samsung LCD
                OK, your pictures are too blur to use, so I found good pictures at SJ.
                Since it blows the main AC fuse, so the shorts will be in the load some where so:
                Check the resistance between the two legs of the main filter cap CP815, if it shows <100 Ohms or so, then remove the fuse FM802S to see if the low resistance will go away, if not then you have shorts circuit in the main power supply/ PFC Voltage booster section, if the shorts go away then the shorts are probably in the switching power supply or in the inverter section.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  Re: Old Samsung LCD
                  You have include pictures of the inverter boards but you say in your first post that the fuse is blowing on the power supply so surely that's the board you should have initially included with nice clear focused photo's of the top and bottom of the circuit board?
                    Re: Old Samsung LCD
                    It is power supply/inverter board combo.
                    • n01d3x
                      • May 2016
                      • 8
                      Re: Old Samsung LCD
                      Sorry for the blurry pics. Yes this is an inverter\power combo. The resistance on cp815 was around 10, once I removed the fuse it was around 120. Thanks for your help!
                        Re: Old Samsung LCD
                        10 Ohms with the fuse in place, and 120 Ohms when fuse is removed?
                        Then you have two bad section, one before the fuse and also after the fuse, I t should not be that low.
                          09-07-2024, 05:50 AM
                          09-06-2024, 11:40 PM
                          09-06-2024, 08:40 PM
                          09-06-2024, 06:20 PM
