Vizio 50hdtv10a
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Vizio 50hdtv10a
    Dead. No led. No power.
    Fixed!
    Thought it was bad power supply, but it turned out to be a blown surface mount fuse on the main board. (upper left hand quadrant)
    Hope this helps!!!!!!
  • badcop
    • May 2016
    Re: Vizio 50hdtv10a
    Picture is more informative (*><*)
    • tvtimmy
      • Mar 2015
      • 1160
      • usa
      Re: Vizio 50hdtv10a
      Already $old. Check every fuse including surface mounted ones. You will find it.
        Surface Mount Fuses Fundamentals Datasheet
        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
        10-07-2024, 06:07 AM
        TF-FUSE Thin Film Surface Mount Fuses (Very Fast Acting), 0603 Size Datasheet
        FF Series (Very Fast Acting), 0603 Size
        Features
        ● Very fast acting at 200% overload current levels
        ● Low DCR
        ● High inrush current withstanding capability
        ● Fiberglass enforced epoxy fuse body
        ● Copper termination with nickel and tin plating
        ● Halogen free, RoHS compliance and lead-free
        Applications
        ● Notebook computers and tablets
        ● Digital cameras
        ● Memory cards
        ● Toys
        ● Bluetooth earphones
        ● Portable electronic devices​...
        10-07-2024, 05:50 AM
      • bscottjohnston
        Vizio M55-E0 won't power on - fuse intact
        by bscottjohnston
        Vizio PSLL241206M inside an M55-E0.
        Here's an odd one. Why in the world do I have 76 VAC on the fuse when I have measured 115 VAC on the input power cord? Does this point to something known or simply another SMPS problem I need to run down?...
        02-20-2024, 12:18 PM
      • corrize
        A funny fuse story – Lumix LX100 II
        by corrize
        Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
        I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
        The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
        There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
        And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
        10-19-2023, 09:58 AM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
