panasonic plasma( TC-P50X1) 7-BLINKS
  • hmendez86
    • Jun 2015
    • 344
    • united states
    I HAVE THIS PLASMA WITH 7 BLINKS...what i did i took out the SC board out and test transistors and they all seem good.. i saw other posting and they say to jump the sc board but am lost there...could this be the SU and SD boards..any were to start doing..
  • tw2005
    • Oct 2011
    • 6458
    Re: panasonic plasma( TC-P50X1) 7-BLINKS
    7 blink can be SC,SD,SU.
    Re-install the SC but leave the SD/SU disconnected and the 4 Vfg bolts(gnd bolts that earth these to the SC) connections SC41,42,46 not connected.
    ensure sc2 and sc20 are connected.
    next to the SC46 connector there is a 2 pin socket, sc50. Those 2 pins need to be jumped together.
    Turn the TV on and if it turns on without 7 blinks then it's SD,SU or both.
    You would then need to see which one is shorted or just replace both
    Looks like Shopjimmy has heaps of these boards and fairly cheap.
    • hmendez86
      • Jun 2015
      • 344
      • united states
      What about sc3 connected or not connected.
      • hmendez86
        • Jun 2015
        • 344
        • united states
        I did already try it.....what it does blinks one and jumps one and one
        • tw2005
          • Oct 2011
          • 6458
          any chance you could explain it differently?
          i don't understand the jumps one.
          Are you saying you followed the bypass test and it's not 7 blinks but something else?
          Are you saying it does 1 blink every 3 secs? If so then that's another issue and generally that is a bad A-board.
          • tw2005
            • Oct 2011
            • 6458
            everything is normal except the sd,su isolated , + their bolts, and jumper at SC50.
            • hmendez86
              • Jun 2015
              • 344
              • united states
              Yes is 1 is every 3sec red ligth.... is anyone try to fix the board or just replace it..
              I did removed bolts, jump the sc board , did the steps you gave me and that's the coming blinking ligth.....
              • tw2005
                • Oct 2011
                • 6458
                I've got lucky and fixed 1 blink finding corrupted eeprom and another i never fixed. You could have 2 faulty boards. Have you reconnected the sd su plus make sure the earth bolts go back and it 7 blinks again?
                • hmendez86
                  • Jun 2015
                  • 344
                  • united states
                  i already fix it...the problem was the main board, and i find it at friends shop for 45bucks not bad....but were i can find the eeprom from this boards it might be a damage eeprom..
                  • tw2005
                    • Oct 2011
                    • 6458
                    Interesting, so the 7 blink was actually a main board issue too?
                    For the eeproms, there's actually several types and also flash ICs as well.
                    I don't know which one to try, it was the one that held the panel address data on the 2 I fixed but I've had no luck with 2009 model just 2010.
                    If it's corrupted data you could use a reader to copy off the good board and the write it to the corrupted one.
                    You can order these chips programmed from sears or encompass spares
                    • tw2005
                      • Oct 2011
                      • 6458
                      This is what I got as a list of all the eeproms etc for this model. May not be able to get all as I see some say restricted Panasonic use only.
                      I can't say for sure replacing any of these will be a fix unless you just want to have a play and see if you can.
                      Good luck with it.
                      https://www.encompassparts.com/model...0%22_PLASMA_TV
                      Part Number Description Demand
                      TVRQ589ABS Ic Y
                      TVRQ603S Ic Y
                      TVRQ604S Ic Y
                      TVRQ605S Ic Y
                      TVRQ587ABS Ic
                      TVRQ590ANS Ic
                      TVRQ592ACS Ic
                      TVRQ598S
                      • hmendez86
                        • Jun 2015
                        • 344
                        • united states
                        thanks very interesting....wondering about eeproms its is easy to progam and what programer i need... it is a save money pocket when you know to program a ic eeprom...
                        • jm1234
                          Panasonic plasma TX-P42ST50 - 6 blinks
                          by jm1234
                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                          I checked that board for any obvious faults...
                          05-22-2024, 06:59 AM
                        • stecos
                          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                          by stecos
                          Hi everyone!
                          I happened several times, in the search for help from the web, to consult this very interesting forum.
                          So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                          Having said that I come to the gist of my post on the forum as the title suggests.
                          For my passion for technology I'm now collecting several...
                          11-28-2022, 11:39 AM
                        • Eaglecrest
                          Panasonic plasma color stripe
                          by Eaglecrest
                          I have a 50" Panasonic that has a color stripe that shows up much of the time. See attached picture, what could cause this?
                          11-05-2025, 06:16 PM
                        • Alicat
                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                          by Alicat
                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                          Model number is TH-50PZ85U
                          Power comes on and the red power light stays on solid.
                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                          I also hear a few clicks.
                          I also think my parents said there was a thunderstorm and the TV failed after that.
                          Section 6 in the service manual talks about power and no screen,...
                          10-30-2024, 10:09 AM
                        • Lintesir
                          Panasonic P42S30 Plasma - Pink sparkles
                          by Lintesir
                          My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
                          There is about a 5cm high region at the top without any sparkles,...
                          07-26-2024, 03:16 AM
