Sanyo fw65d25t no picture; good sound
  • dcsharpsr
    • Nov 2013
    • 28
    Re: Sanyo fw65d25t no picture; good sound
    Nomoresonys... Nice video and explanations of the power supply, main and T-con modules. I might be able to troubleshoot the missing n3.3v on the main board. Probably a bad regulator. Thanks for sharing. Still looking for a replacement main board.
    Don
    • dcsharpsr
      • Nov 2013
      • 28
      I finally found a main board and installed it. It WORK!! But now sometimes on power cycling sometimes it comes up with pictures and sometimes not... only a backlight. I scoped the main board and found signals going to the frc module inputs but no outputs to the T-Con. The regulator on Frc shows normal voltages of (top to bottom)
      .6v
      1.8v
      3.3
      I finally found the service manual of 33 pages which is really a degrace. No schematics. Poor troubleshooting tips. No real help at all. I replaced the frc but same issue. What turns on the frc outputs?
      • dcsharpsr
        • Nov 2013
        • 28
        Oh... and that strange blinking windowed message is now gone. It must have been the eprom on the other board
        • nomoresonys
          • 12276
          • U.S.
          #84
          Maybe it's a problem on the frc board, since the signal comes in but doesn't make it out.
          • dcsharpsr
            • Nov 2013
            • 28
            I'm thinking the same but I changed it out with with the same issue. Since I'm now thinking the main board must turn on the function of the frc. Heck... I don't know why it's intermittent.
            I did have a problem with the key switches with a broken wire so it was disconnected when it I had pictures. After resoldering the wire back on and pluging back into the main board, it stopped showing pictures. I found the 3 3v from the main board dissappeared so I unplugged the key connector but still no pictures now. The 3.3v on the main board came back.
            • nomoresonys
              • 12276
              • U.S.
              #86
              not sure what all was tried, did you try unplugging the button board, speakers and wifi module? just to make sure none of them are causing the problem.
              • Mgiffune
                by Mgiffune
                06-09-2024, 10:28 AM
              • TR103
                by TR103
                - it keeps rebooting
                01-22-2025, 04:12 PM
              • jord4231
                Toshiba 37AV500A Regza TV good power supply no sound no picture
                by jord4231
                Hi Everyone,
                I'm working on a Toshiba 37AV500A Regza TV.
                The issue:
                TV was working picture and sound went out. Green stand by light stayed on, It will respond to the power button being pressed (goes in and out of standby)
                The TV will very intermittently work for around 40 mins then stop. This doesn't seem to matter if its hot/cold unplugged for a while etc.
                I checked the PSU voltages and everything looked good.
                No bulging caps or signs of heat.
                24v aud = 24.41v
                12v = 11.98v
                5v = 5.062
                p_o/f = Goes high...
                03-29-2022, 09:21 PM
              • Ierwin
                by Ierwin
                05-13-2025, 03:31 PM
              • jchang
                Samsung UN70NU6900F no picture and no sound
                by jchang
                Hi all
                I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                Symptom:
                No picture no sound.
                When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                No sound at all.
                What I tried:
                1. I tried unplugging the left or right ribbon...
                01-09-2023, 06:28 PM
