Samsung le40b652t4w Video Issues
  • speedypro
    • Feb 2013
    • 561
    • United Kingdom
    Could someone help me diagnose this? This TV works when powered on but after 15 seconds, the picture is gone. Sound is still present. Power off tv and power back on the cycle repeats.
    Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Samsung le40b652t4w Video Issues
    Shine a torch onto the screen and press menu on your remote and carefully look to see if you can see anything on the display. Move the torch around.
    • jasonr2000
      Advance Tech
      • Nov 2013
      • 209
      Sounds like it could be a t-con issue if the picture comes and goes after 15seconds
      Samsung UE46D6530
      Samsung BD-F7500
      Samsung HT-ES6200
      • speedypro
        • Feb 2013
        • 561
        • United Kingdom
        Yes it's the tcon. Found two shorted transistors
        • speedypro
          • Feb 2013
          • 561
          • United Kingdom
          Ok found these shorted trans.
          Red circle: 1117 0910DG
          Yellow: L176 950 145
          Anywhere I could find these or other names they come under?
          • jasonr2000
            Advance Tech
            • Nov 2013
            • 209
            Hi speedypro
            I'm not sure on the best place to get the parts but have u tried to find another tcon ? eBay may also have the parts your searching for
            Samsung UE46D6530
            Samsung BD-F7500
            Samsung HT-ES6200
            • speedypro
              • Feb 2013
              • 561
              • United Kingdom
              Originally posted by jasonr2000
              Hi speedypro
              Yes I have seen many but the thing is, I like to fix and not put boards in the bin. I am sure those used boards will eventually fail soon.
              • jasonr2000
                Advance Tech
                • Nov 2013
                • 209
                you make a valid point there speedy is it just them that have failed ??
                Have you tried cooling them to see if the picture stays longer ?
                Samsung UE46D6530
                Samsung BD-F7500
                Samsung HT-ES6200
                  'Red circle: 1117 0910DG' That is 1117 series regulator IC, not transistor.
                  'Yellow: L176 950 145', (need verification on those numbers) That is also IC, that is why the desigantors are labeled as ICxxxx.
                  The question is, what DCV do you have on the legs?
                  • speedypro
                    • Feb 2013
                    • 561
                    • United Kingdom
                    Sorry it's an L176 950T45
                    Got voltages of ~2v to ~3v
                      We need the dcv readding of each pin so we can see what you have for the input pin, output pin, and ADJ pin.
                      • speedypro
                        • Feb 2013
                        • 561
                        • United Kingdom
                        Guess it's not the t-con after all; the issue is with the power board: psiv231101a
                        Yellow circle is where I can hear a weird sound then after the sound cuts out, so does the backlight.
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          Have you measured the secondaries and primary resistance of each of the inverter transformers to see if the circled one is different.
                          • speedypro
                            • Feb 2013
                            • 561
                            • United Kingdom
                            Yes I have. From 1.5k ohms to 1.6k ohms. I'll be replacing the 1.6.
                            • martino
                              Not so "senior"
                              • Aug 2013
                              • 997
                              • canada
                              Did you take that plastic holder out with the power board?
                              I'm not sure but doesn't that plastic hold the tubes in place behind the screen? Or is this a different model and I'm mistaken?
                              Proud owner of dozens of broken TV's and many,many,many boards.
                              Our website and passion:http://hollenhundshepherds.com/
                              • speedypro
                                • Feb 2013
                                • 561
                                • United Kingdom
                                That black strip should have stayed in but the bulds are ok. Im glad. Ive never pulled apart these before. But bulds are ok
                                  GeForce RTX2080 Super Aero video gaming card issues help need
                                  by sam_sam_sam
                                  This is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
                                  Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it...
                                  05-07-2023, 08:12 AM
                                  09-07-2024, 05:50 AM
                                  09-06-2024, 11:40 PM
                                  09-06-2024, 08:40 PM
