Panasonic Viera 14 Blinks Now Steady Light
    Hey guys a few weeks ago my plasma (p42s30) wouldn't turn on and the LED light flashed 14 times. With some research, mostly from bapcaps, I narrowed it down to the SS and SN board, both of which I replaced. Now, the TV just shows a steady red LED light.
    With both boards connected, pressing the power button on the remote does nothing, however, if I disconnect the SN and keep the SS plugged in, I can press the power button and it will turn the light off and on (still steady). Now, I'm assuming there's something wrong with the power supply board since it stays in stand by mode but still doesn't show any picture or sound. Could a bad power supply board cause the other boards to go bad and would replacing it fix my TV? Thanks in advance!
    Re: Panasonic Viera 14 Blinks Now Steady Light
    Did you look at the service manual?
    Usually Panasonic have steps you can follow to diagnose things.
      Power supply. Had one do the same thing.
        14 blink implies Mainboard failure....
        --usually associated with hdmi controller...
        TELEFIX
          14 blinks on this model is almost always the sn board. My guess is you got another faulty sn board. When the tv is on with the solid red light. Hold the power button down until the blink code appears again. My guess is it will be 14 blinks again. Hope this info helps you out.
