sanyo dp55360 LED tv restarts
  • ALR
    • Nov 2012
    • 111
    Hi, I have an LED tv that is restarting itself every 1.5 hours it seems like. I'm leaning toward a mainboard fault on this? Doesn't seem like the psu would be at fault since it stays working for so long and starts right back up, it doesn' tpower off, it restarts itself.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: sanyo dp55360 LED tv restarts
    It may be worth removing the back cover and use a hair dryer to heat up the circuit boards to see if you can bring the fault on quicker in an attempt to identify the area causing the fault.
    • ALR
      • Nov 2012
      • 111
      Found fault in mainboard. Replaced with a used one...Worked great...For about 6-7 days. Now the tv shows no power. From reading, It seems the common no power issues with the main board are in the audio circuit, IC1670. I'm going to buy this v5806 IC module, http://www.ebay.com/itm/1x-LV58063MC...AAAOSwEeFVJadA
      Anyone repair either no power issue or random restart every hour by replacing this IC?
      • Prosatanosz
        Asus B85M-GAMER no hdmi output and random restarts
        by Prosatanosz
        Hi!
        Asus B85M-GAMER absolute no hdmi output (not at start, not at Windows), and random restarts. Everything work, except hdmi and random restarts after 0.1-3 min. Restarts even in bios. On VGA Windows boots up fast, games and apps starts ok. Mem, psu, cpu changed, no luck. I need shematic, because i think the restarts caused by the hdmi failure.
        10-19-2024, 05:27 AM
      • Rictech
        Panasonic SA-MAX770PU SMPSU board fault....
        by Rictech
        Hello everyone. 😀
        As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
        Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
        Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
        This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
        There are no devices that have exploded or otherwise show signs...
        08-26-2024, 01:05 AM
      • howardc64
        Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
        by howardc64
        • Prior owner tried a replacement main board. No difference.
        • Samsung 2x red blinking standby LED = panel fault
        • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
        • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
        • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
        07-19-2025, 10:54 PM
        ESR meter came to the rescue again today with a PLC I/O card fault
        I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
        I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
        One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
        12-18-2023, 08:17 PM
      • Agent24
        What kind of fault causes this image error?
        by Agent24
        I took a look at a television for a friend, it has some serious image fault. I don't know what the cause is or if such a fault is even repairable.
        The T-con board seems to be integrated into the panel so looks even more annoying to work on than normal.
        What's the most likely cause of this problem, does anyone know?...
        09-22-2025, 11:42 PM
