Technika LCD 40-270 Voltages Gradually Drain
  • steved271
    • Jan 2014
    • 29
    • England
    i have a 40 inch Technika LCD that was gifted to me as it just sits with the Red Power LED showing....
    when the standby button is pressed, it just does nothing....
    i assumed it was the power board that was at fault so ordered a replacement... this does exactly the same thing... but can not confirm whether this was a good board when it was purchased....
    so i decided to do some diagnostics..... when i test the voltages when i press the power on button and i get 24v but as i go further down the power starts draining to zero volts....
    is this because it has done its tests found a fault and powering down?
    I am about to check the Voltage sent to the LCD power board on the far left and see if this gives me any voltage
    If anyone has any ideas i would appreciate them
    steve
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Technika LCD 40-270 Voltages Gradually Drain
    Common issue on the, trash TMSD boards it eh epprom that stores the firmware fails causing a similar issue. Have you dissconected the inverter and tried to power on the Tv ?
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Can you check your power supplies on the bench and see if both of them come up with the expected voltages normally written on the PCB alongside the connectors?
      • steved271
        • Jan 2014
        • 29
        • England
        Reece, I am still working on this one.... Its not an urgent fix as just one i got as a throw away.... I disconnected the Inverter board and nothing happened.....
        Because the Voltages come up as the set tries to power on and then drains away after about a minute, I am guessing something is tripping the protection circuit.... I tried another inverter which i know is good....
        I saw from one of your vids about the Caps on the main board.... I am going to see if i can get hold of a Cap meter to test those.... but will look for the EEPROM and see what it is.... Any Tip on where to get a replacement or where to get the firmware from?
        Dick, All the voltages check out fine..... Its just when the standby switch is pressed that it sits for a moment and then the voltages drain to zero....
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          I have just replaced the mainboard on a Technika 46-270 after being stuck in standby.
          Do you have access to a scope? I scoped the clock line of the SPI chip (U10) when I tried to take it out of standby but there were no clock pulses to be seen.
          A replacement motherboard was ordered because I considered that the main processor was not communicating with the SPI.
          All up and running now.
          • steved271
            • Jan 2014
            • 29
            • England
            Dick, No i dont have access to a scope... Thank you for that... I will order one and see if it gets it working....
            The SPi chip is for the firmware? I been having a nose around and cant find the Firmware from anywhere....
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              If it is the firmware then it's available from
              http://www.ohmsupplies.co.uk/epages/...jectID=6766894
              • steved271
                • Jan 2014
                • 29
                • England
                Cheers, I will get that ordered today and and post back when i have replaced it...
                • steved271
                  • Jan 2014
                  • 29
                  • England
                  Just a Quick update on this .....
                  I replace the U10 as suggested above and the TV Powered up like a dream....
                  Thank you for the advice
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    Well done and thanks for the update which could prove useful to others with a similar fault.
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Good work again
                      • steved271
                        • Jan 2014
                        • 29
                        • England
                        Its always good to post the fix so others can benefit from it
                        • Capacitorial
                          Powersupply has all the voltages - Monitor still no power
                          by Capacitorial
                          Hello guys,
                          I have a Philips 240B7QPJEB. The monitor seems completely dead.
                          I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                          On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                          The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                          The weird thing is, that the Power LED is powered over the TCON board.
                          On The TCON...
                          12-28-2024, 02:12 PM
                        • gjgib
                          Help reading schematic voltages input/output
                          by gjgib
                          Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
                          I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
                          I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
                          I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
                          05-06-2024, 08:11 PM
                        • RossMoodley1967
                          HISENSE LCD LED TV MODEL HX40N2176F LED DRIVER SN51DP IC PINOUT AND VOLTAGES
                          by RossMoodley1967
                          Hello
                          Need to know the voltages that will be present on SN51DP ic when tv is in standby and when powered on.
                          Just to elaborate on the problem with the tv 1.set came in with flash of HISENSE logo on screen then back into standby.2. Now tv when plugged in red standby light present to quickly changes to blue but no backlights.3.Then an hour ago i checked again , came on standby and stayed until i pressed the power button which changed to power on (blue)4.As far as the led driver circuit goes voltage at output in standby was 38v , power on led light up voltages rise 58v-68v...
                          03-01-2024, 06:07 AM
                        • karlp028
                          MSI Z390-A PRO missing VCORE voltages
                          by karlp028
                          I've got an MSI Z390-A Pro motherboard that starts up fine, but it's missing the VCORE (and VGT) voltages. All of the other voltages are present (e.g. VCCSA, VCCIO) and I know the CPU (i7-9700k) is good. Now, the original PWM controller (UP9521P) had an internal short and I replaced it with a new one. All of the enable signals look good. The problem seems to be the PWM signals going to the MOSFET drivers. I checked them with an oscilloscope and they are all flat 1.5V with no pulses. I don't know why this would be and I'm not sure where to look next.
                          06-23-2025, 01:25 AM
                        • lol999
                          Asus Prime x299 Deluxe - no VCCIO VCCSA voltages
                          by lol999
                          Motherboard after starting show Q code 00.
                          No shorts on any rail ( at last I can't finde any)
                          All voltage are correct on SIO - 3.3V, PCH power 1V , DDR 1.2V, SPI 8 leg 3.3V
                          Nothing get hot, PSU starting, all lights came ON....
                          One thing i can see incorrect is no VCCIO and VCCSA voltages and no main power on CPU.
                          After deep looking I found dead Synchronous Buck converter CSD97374Q4M that is powering VCCIO for CPU but after replacing it nothing changed. Voltages on it are correct....
                          This buck converter is PWM'ed by Asus DigiVRM ASP1405I-62T. Can't finde any datasheet...
                          01-21-2024, 02:25 PM
