LED Modul Light for LCD TV, Edge LED, PLUS LED suggustion
  • Diah
    • Feb 2013
    • 6562
    here are the list and most best purchased seller for good quality and fast post on cheap price for LED Mosul back light hope it help you to have under hand store.. all sources are tested and perfect...don't miss to visit sellers before you write here thanks.
    40 size TV, Toshiba, Philips, Vistel, Medion, Grundig, Vizion, and more... LED Modul 7030 6 Volts current 260 mA Lumens 70Lm lot 100 pieces round 6 USDLINK
    42-43-47.48-49- more Samsung LG Toshiba, Grundig, Vizion, Philips, ans more LED module 3528 LG brand round 10 USD
    Forward Current:400mA Forward Voltage:3.05-3.65V umens:100LM from HIER
    same specification from OEM less than 1,50 USD tested OK from HERE
    all sources tested and the best in the market. enjoy.
  • Diah
    • Feb 2013
    • 6562
    Re: LED Modul Light for LCD TV, Edge LED, PLUS LED suggustion
    all purchasing are for LOT 100 pieces, more cheap will be not. lol
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Cheers there are some cheap 0.5w SMT ones on ebay which have very similar specs and will work fine. I have some on order.
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        Do you also build your own christmas tree lights with leds , Reecey?
        Just kidding! What are your opinions about LED vs CCFL? Personally i would go for CCFL , its a more relaxed image.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Haha have not got the effort to do that I prefer CCFL anything electronic that uses gases to produce light is always alot more reliable. IMO the image on Led backlit Tv's (good ones not Vestel craps) is alot better than even high end CCFL backlit Lcd's but Led Tv's just do not last longer if its not the Leds going pop its the Lcd screen which as you know is unfixable in almost every case.
          • Moreno83
            • Jun 2014
            • 2008
            • The Netherlands
            You would expect that the lcd screens would last longer nowadays? Well i prefer my Philips 8404 over a samsung led tv!!
            Did you ever use LED in a CCFL backlight tv? If so , please make a vid
            • Diah
              • Feb 2013
              • 6562
              the one you talking about all will make smoke when Tv turn on LOL... dont let customer TV being smoker
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                What do you mean bud ? Putting Leds in a previously Cfl Tv ?
                • Diah
                  • Feb 2013
                  • 6562
                  he was kidding with you lol
                  tom66 can d it or...
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    What do you mean lol ?
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Hope not haha ohh well worth a shot
                      • Moreno83
                        • Jun 2014
                        • 2008
                        • The Netherlands
                        I mean , before led backlight the lcd tv's used CCFL backlight. For example my Philips ambilight has tubes.
                        Is it a easy modification to replace the CCFL with LED?
                          • 31285
                          edge-lit are easy and kits are cheap.
                          backlit are hard, you have to get the spacing between the led's right for focus angle and distance to the defuser or you get light and dark patches.
                          • Moreno83
                            • Jun 2014
                            • 2008
                            • The Netherlands
                            You mean , same effect as 1 bad CCFL?
                            Just 1 strip with LED , you still need a new diffuser? And also , how can i dimm the led's?
                              • 31285
                              worse than bad cfl - that's a dark line, i mean bright and dark patches like a grid.
                              led's are dimmed by the led driver board - usually pwm i think.
                              that's the hard part, you need to get an led driver that has the same dimming control as the cfl invertor.
                              or just not connct it and run fixed brightness.
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                It is possible to do, just use some pre-made strips out of smashed Tv's I would say use 4 strips of about 11 leds for a 32" size. But Stj is correct you need to make sure that you get the spacing correct of the Leds if not you get bright patches on the screen which looks horrid.
                                • howardc64
                                  by howardc64
                                  Problem
                                  08-04-2024, 10:36 PM
                                  LENOVO ThinkCentre Edge 71 ThinkCentre Edge G630 Specification for Upgrade or Repair
                                  This specification for the LENOVO ThinkCentre Edge 71 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre Edge 71 boardview and ThinkCentre Edge 71 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  09-12-2024, 03:36 PM
                                  LENOVO ThinkCentre Edge 71 ThinkCentre Edge i5-2400S Specification for Upgrade or Repair
                                  LENOVO ThinkCentre Edge 71 SFF ThinkCentre Edge G630 Specification for Upgrade or Repair
                                  This specification for the LENOVO ThinkCentre Edge 71 SFF can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre Edge 71 SFF boardview and ThinkCentre Edge 71 SFF schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
