Toshiba 32AV500U No Picture, but responds to remote
  • TechGeek
    Computer Geek
    • Jan 2015
    • 2254
    I received this TV today in nonworking condition. The issue is that you would plug the TV in, turn it on, and the display would do NOTHING. Not even power up the backlight. I took the entire thing apart, and there's no bad caps or loose connections. I put it back together, and put batteries in the remote. It is responsive to commands from the remote, like volume up/down, and power on/off. I don't know how to change inputs on the thing, because of no display. I have tried the light trick, but either I'm doing something wrong, or the LCD is gone. I can't see anything. Can anyone please help? Thanks!
    Permanently Retired Systems:
    Kooky and Kool Systems
    sigpic
    Re: Toshiba 32AV500U No Picture, but responds to remote
    So the backlights are not working, the next step will be up loading good clear pictures of the whole back side of the TV showing all the boards.
    You will need to find out if the inverter board is getting the bl-on and the dimming control signals or not.
    • TechGeek
      Computer Geek
      • Jan 2015
      • 2254
      I guess the "bl-on" signal powers up the backlights and the next one is self-explanatory?
      sigpic
        Correct.
        • TechGeek
          Computer Geek
          • Jan 2015
          • 2254
          Well, sorry for the long delay. I took the TV apart, and took photos of the boards as I disassembled the TV. I'm uploading the photos through my slow mobile data connection on my phone, so photos are coming later.
          sigpic
            Doing the search on badcaps.net using 'Toshiba 32AV500U'
            https://www.badcaps.net/forum/search...archid=6027351
            Lots of threads come up about no backlights, so you may want to read those threads.
            • TechGeek
              Computer Geek
              • Jan 2015
              • 2254
              Error: "Sorry- no matches. Please try some different terms."
              sigpic
              • TechGeek
                Computer Geek
                • Jan 2015
                • 2254
                Okay, here are the requested photos.
                sigpic
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  Try again, there are several results.
                  • Diah
                    • Feb 2013
                    • 6439
                    here you are, attached the service manual for this set, go head to page 11.
                    • TechGeek
                      Computer Geek
                      • Jan 2015
                      • 2254
                      How would I go about troubleshooting the master and slave inverter boards? I've already tried unplugging slave and leaving the master board plugged in, and reversing that configuration. Nothing has helped so far.
                      sigpic
                        OK, so it uses Master/Slave inverter boards set up, so there is fuse on each of the inverter board so you need to find out if you do have 24VDC at BOTH ends of the fuses using chassis as the GND ref. for the meter when TV is turned on.
                        Per service manual page 9, connector P202 pin 12 is the BL_ON (ON/OFF).
                        • TechGeek
                          Computer Geek
                          • Jan 2015
                          • 2254
                          Voltages are:
                          Master:
                          Before fuse: 24VDC
                          After fuse:24VDC
                          Slave:
                          Before fuse: 24VDC
                          After fuse: 2.2VDC
                          sigpic
                            Voltages are:
                            Master:
                            Before fuse: 24VDC
                            After fuse:24VDC
                            Slave:
                            Before fuse: 24VDC
                            After fuse: 2.2VDC
                            You need to check the Power MOSFETs on that SLAVE board.
                            • TechGeek
                              Computer Geek
                              • Jan 2015
                              • 2254
                              How?
                              sigpic
                                Get the P/N of the MOSFETs, then search for the spec sheet to learn what the pin of the MOSFETs are and then test the RESISTANCE between Source pin and the Drain pin to see which one is showing really low resistance (<100 Ohms).
                                BTW, that big SMD IC will usually go bad too.
                                http://www.ebay.com/itm/Toshiba-HIU-...3D172005301978
                                http://www.shopjimmy.com/catalogsear...ult/?q=HIU-813
                                Toshiba HIU-813-M (HPC-1655E) Backlight Inverter Master
                                Toshiba HIU-813-S (HPC-1655E) Backlight Inverter Slave
                                • TechGeek
                                  Computer Geek
                                  • Jan 2015
                                  • 2254
                                  MOSFET 3 has failed. 18 ohms.
                                  sigpic
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    Also check the controller IC ! Seen alot of them blow up check the VCC to ground it can make the mosfet show up shorted if its bad.
                                    Image showing the same IC that I had to replace it was making the mosfet show up as shorted but the fet was fine and it blew the fuse, the controller was the cause:
                                    • TechGeek
                                      Computer Geek
                                      • Jan 2015
                                      • 2254
                                      Is that on the single-board TVs?
                                      sigpic
                                      • ReeceyBurger123
                                        Never Give Up !
                                        • May 2014
                                        • 7325
                                        • Britain
                                        Both master and slave inverter will have that Ic I can see it in the picture above the fets.
                                        • Mc_Millian
                                          Toshiba 50lf711u20 fire tv remote not pairing
                                          by Mc_Millian
                                          I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
                                          The Tv model number is: 50lf711u20 Rev B.
                                          I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
                                          I've tried 3 different remotes which should be fully compatible with this TV.
                                          Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
                                          The power button, along with the volume,back,select, and directional...
                                          04-07-2022, 12:15 PM
                                          09-06-2024, 05:27 AM
                                          09-06-2024, 05:59 AM
