Samsung LE37S86BD volume at 255 or 200% when turned on
  • noledud
    • Dec 2013
    • 413
    • united kingdom
    Hi All
    This is a strange one and i think it needs the firmware updating but want to get your input
    The set came to me with the fault that the volume is stuck on full
    I thought it would be the side buttons and was hoping for an easy fix
    Got the set and it needed some caps on the PSU and also a new gamma chip on the tcon
    The simple fault with the volume looks anything but simple - when you first turn the set on the volume is full, well in fact double full its well over the the right hand side of the screen !
    It allows you to turn it down and the bar starts moving left but leaving a distorted picture behind. When you eventually get to where full would be if in the center ( ie normal full ) the sound goes back to full. You can then use the volume as normal all the way down and back up but the distorted bar left behind always remains
    It would be ok if it didn't leave the bar on the right
    Iv tried a reset from service menu and had a good look for sound options that might effect it but cant find anything.
    Im think firmware update would fix but with no usb that wont be easy
    any thing else i can try ?
    I have scrap boards from similar sets so if i knew what chip was at fault i could try swapping
  • PatrickSaw
    • Nov 2015
    • 20
    • Spain
    Re: Samsung LE37S86BD volume at 255 or 200% when turned on
    Hello!
    I've exactly the same faulty, on a Samsung LE32S67BD. Distorted bar included.
    Have you advanced anything?
    • mmartell
      • Oct 2013
      • 3189
      I would guess bad cells in either your serial flash ic or eeprom. If you get the volume down to normal and power cycle the tv with the remote does the volume remain normal ?
      • PatrickSaw
        • Nov 2015
        • 20
        • Spain
        Nope, OFF-ON and again volume at 200%. How could I fix serial flash or eeprom? With no USB, I cant update firmware...
        Thanks!
        • CapLeaker
          Leaking Member
          • 8184
          by replacing it on the main board.
          • PatrickSaw
            • Nov 2015
            • 20
            • Spain
            PD: well, I'm going lookig for a main board...
            • PatrickSaw
              • Nov 2015
              • 20
              • Spain
              Hi!
              I have tried the audio jack, and it works perfect with any jack plugged. So I'll take the audio from there, instead of replace main board.
              • noledud
                • Dec 2013
                • 413
                • united kingdom
                Hi all
                Ok update so far
                Iv tried a new Eeprom chip still the same
                Where is the serial flash located and does it have to be blank or pre programmed
                Set aint worth putting a nice sound bar with it lol
                  09-07-2024, 05:50 AM
                  09-06-2024, 11:40 PM
                  09-06-2024, 08:40 PM
                  Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                  This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-06-2024, 06:20 PM
