lg 34px3rva
  • andyfitz48
    • Feb 2016
    • 17
    • united kingdom
    lg 34px3rva
    Hi folks
    1st post so apologies for any noobiness
    Ive been given an old LG plasma to look at 42px3rva which has the seemingly common sound but no picture problem.
    I opened it up and saw a blown 350v cap on the y sus (c26 I think) which I replaced.
    When I put it all back together a resistor right next to the cap glowed red and blew.
    Now I cant see what value the resistor is.
    So, 2 questions please
    Is it common for it to be another failed component on the y sus which has caused this and if so is it worth replacing the resistor?
    Does anyone have a schematic for this board or otherwise know the value of resistor I need?
    Many thanks
    Andy
  • Agent24
    I see dead caps
    • Oct 2007
    • 5095
    • New Zealand
    Re: lg 34px3rva
    Sounds like a power transistor or something has gone shorted.
    You need to upload photos of the boards, the whole TV with back off, the damaged area, etc etc.
    Also, check the model number, Google only returns this thread as a result so I expect you've got the number wrong.
    -David VanHorn
    • jinu_j
      by jinu_j
      Hi
      05-03-2025, 10:51 PM
    • mikey5791
      Need help to replace burned resistor in 350w atx psu
      by mikey5791
      Hi to all forum members,
      Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
      The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
      Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
      Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
      12-26-2024, 04:55 AM
    • MidnightRoller
      Can a resistor lose resistance after hot air?
      by MidnightRoller
      I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
      I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
      02-02-2022, 11:46 PM
    • artvandalai
      What resistor ohm will work better to repair this waterpik?
      by artvandalai
      The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
      01-05-2025, 04:10 PM
    • chth96
      Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
      by chth96
      I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
      Since then, This AC/DC adaptor have been out of order.
      But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
      After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
      And Is there any possibility that it will suddenly explode as well as to be out...
      12-03-2023, 04:40 AM
