VESTEL FIRMWARE: Toshiba 32W1333B
  • yokoono
    • Apr 2010
    • 510
    #41
    Re: VESTEL FIRMWARE: Toshiba 32W1333B
    Hellen Sie den Bildschirm mit einem stärkeren Licht auf und prüfen Sie, ob es sich um ein Bild handelt. Ich denke, Sie haben Probleme mit der Hintergrundbeleuchtung, nicht mit der Software. STB LED AUSSEHEN, WIE FERNSEHEN NORMAL FUNKTIONIERT?
    • Magio
      • 14
      There is no picture to be seen unfortunately. Tried it. I made a picture from what's inside showing all LEDs / Backlight working.
      It doesn`t start the update though
      • arizanotlari
        • Nov 2014
        • 158
        • Turkiye
        #43
        you must press and hold "ok" from rc until stby led blinking.
        https://www.badcaps.net
        • yokoono
          • Apr 2010
          • 510
          #44
          To get an update to a Vestel card is a procedure. In the USB stick, press and hold the OK key on the remote control, put the TV in the socket. When the stb LED flashes quickly release the OK key. Wait for the update to finish (2-3 min.).
          If you do not have an image it can be the problem in the t-con.
          • Magio
            • 14
            Originally posted by Magio
            There is no damage. The backlight tries to adjust brightness as well, so I see it going darker. No further reaction though
            Oh got the misunderstanding. No there is no image I can see unfortunately, tried with a super bright LED flashlight. When switching programs up and down the backlight becomes brighter and adjusts itself again back to black with less brightness.
            • Magio
              • 14
              Thought about the T-Con board though, but replaced the 17MB95M. Is there a specific T-Con Board for this model? Isn't that backlight controller with a fix connection to the LCD panel cable attached?
              • yokoono
                • Apr 2010
                • 510
                #47
                Can you take a picture with the back of the TV? Without cover.
                • Magio
                  • 14
                  Sure, there we go:
                  That's what's the T-Con says. innolux mv-0s94v-0E88441
                  • yokoono
                    • Apr 2010
                    • 510
                    #49
                    T-con is part of the panel. Near the connector is a fuse. See if it's good and you have 12v (or 5v) on both ends.
                    • Magio
                      • 14
                      11.3V it's showing.
                      • yokoono
                        • Apr 2010
                        • 510
                        #51
                        So the t-con is feeding. Search now for t-con measuring points VGH, VGL and see what values you find.
                        • Magio
                          • 14
                          2.2mV on both, assuming I have found the right one. Pretty sure to have measured VGL, not sure if VGH was the correct one though.
                          • yokoono
                            • Apr 2010
                            • 510
                            #53
                            That's not good. VGH is positive voltage and can exceed + 20V. VGL is negative voltage and is around -6V. There is a dc-dc converter that generates these voltages. If it is burned it can be replaced. Or it may be a short in the panel. Or a short on one of the 2 rails (smd capacitor in short, diode, etc.). Measure the resistance on them against the ground.
                            • Magio
                              • 14
                              I have belled through all available SMD parts against ground and almost all of them seem to be sound. Where can I check the DCDC converter?
                              What rails do you mean exactly?
                              • yokoono
                                • Apr 2010
                                • 510
                                #55
                                Rails: vgh, vgl, 12v, 5v, 24v etc.
                                What resistance do you find on VGH?
                                The VGH measurement point starts from the integrated one.
                                • Magio
                                  • 14
                                  VGH and VGL are both about 740 Ohm against Ground. If I bell it through VGH against VGL it seems to be connected.
                                  Wait a second. Just checked it with a magnifier. I measured VCH instead of VGH. The only one I found on the board sort of similiar to what you said is VGHP and has a value of 48 kOhm.
                                  Just to clarify:
                                  So, VCH and VGL are connected with each of them 740 Ohm against ground. VGHP has 48 kOhm,
                                  • yokoono
                                    • Apr 2010
                                    • 510
                                    #57
                                    This means that the integrated dc-dc converter is defective. If you can take a close up picture I'll tell you what it is. But I don't think you have the tools to replace it. The t-cone being glued to the panel does not pose the problem of its replacement.
                                    • Magio
                                      • 14
                                      which tools would I need, I got a hot air gun somewhere and to be honest, can't make it any worse anyway Let me take some close up pictures first.
                                      There we go:
                                      • yokoono
                                        • Apr 2010
                                        • 510
                                        #59
                                        This is the dc-dc converter that I think is faulty. After it is detached, measure between VGL and VGH. If it is shorter it means that the fault is in the panel.
                                        • Magio
                                          • 14
                                          and where to get a new DC-DC?
                                          • anlu
                                            Vestel Firmware - Toshiba 32W133DN
                                            by anlu
                                            Hello, i have an old Toshiba 32W1333DN (sorry, misspelled the headline) TV that had the standby led green/red flashing and no lightup problem, i repaired it by measure the led output as suspect led problem, i measured the LED:s one by one and found one bad led, i replaced the the led-straps and the TV works.
                                            Now i need to update the software because the new rc "RM-L890" does not work and i think maybe it could be an firmware issue?, i have struggled to find it without any success because all of the links where invalid, i contacted Toshiba but they do not support this model...
                                            02-04-2023, 12:59 AM
                                          • cheeky2
                                            Toshiba 49U7763DB (Mainboard: Vestel 17MB120) firmware issues after sporadic power cu
                                            by cheeky2
                                            I have this Toshiba 49U7763DB Tv which was suffering issues after various electrical power cuts, which happened in quick succession
                                            Originally the TV was powering on and then very shortly powering off. I managed to get into the menu structure before powering off and carry out a first time installation of the TV. Which didn't make much difference. I have managed to factory reset (that didn't make any difference either).
                                            The firmware inside the 17MB120 is corrupted and is causing some strange issues so my question is does anyone have any suitable firmware for this model?
                                            Details:...
                                            08-17-2023, 04:34 AM
                                          • Bazilwrc164
                                            Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
                                            by Bazilwrc164
                                            I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
                                            The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
                                            I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
                                            If anyone can provide:
                                            • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
                                            • Or a compatible EEPROM dump
                                            07-23-2025, 12:15 PM
                                          • DarrenHD
                                            Firmware for older Toshiba TV 22CV100U
                                            by DarrenHD
                                            HI all, Does anyone know if there exists an archive for older firmwares for Toshiba TV's? I've searched all over Toshiba's various websites and also on Dynabook's site (they say they deleted all old firmwares due to "server space". ) Toshiba has not replied to my request.
                                            I'm looking for Firmware 1.07 for the 19/22/26/32 C100U series as described in this link:
                                            https://support.dynabook.com/support...tentId=2865076
                                            Thanks!
                                            06-16-2025, 11:56 AM
                                          • RAZ777
                                            Toshiba 40L3653DB Vestel firmware
                                            by RAZ777
                                            Hi Guys,
                                            I have a Toshiba 40L3653DB with flashing green/red led - firmware fault.
                                            It has the vestel 17MB110 board.
                                            Anyone know where I could get firmware?
                                            02-16-2022, 07:56 AM
