17IPS19 No Backlight Repair
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Have this 40" Jvc Led Tv, rebadged Vestel junk ! Initially I thought we had a bad led with in the Lcd screen as the Tv has sound but no picture, and shining a torch on the screen shows the Lcd glass is working but the backlight isnt. A common fault on Led Tv's is the Leds are wired in series and normally an Led will pop (due to heat) causing the whole lot not to work.
    On this one, I had no Led drive voltage coming from Psu with or with out Led connector pluged in so I knew the Psu was at fault. Next I checked 24v rail as that is what drives the Led booster circuit and no 24v rail. So I then checked the 3 diodes in parallel for the 24v rail and one was shorted. Easy fix
    Its funny as I had another IPS19 with shorted 24v diode and it would not come out of standby but this does lol. After finding the bad diode by finding the one with lowest ohms across it, I then cut the diode out of cirucit the Tv works but dont run it for long if you do this as it will stress the others due to one not being present. Now just need to order some UF5404 and SB5100 (for 12v rail) its important to replace ALL the output diodes on these supplies when one fails as the others wont be long off blowing up.
    Note: You should check the Led booster mosfet if the 24v diodes do short as it could be damaged by this its surface mounted device under the Psu and has a circuit reference of Q501 or if it uses the through hole type Q502 if this is shorted replace it too.
  • mkdj
    Acer TravelMate P214 - N19Q7 main power rail shorted to ground
    by mkdj
    Dear all,
    I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
    I have checked resistance across each of the 4 MOSFETS. I have the following readings:
    Both N-Channel Mosfets: nothing odd
    P-Channel MOSFET number 1:
    source - drain : 117 kOhm
    source - gate: 96 Ohm
    gate - drain: 117 kOhm
    P-Channel MOSFET...
    08-20-2025, 06:08 AM
  • Dvsr
    On M-Audio AV40 active studio speaker's two zener diodes get really hot.
    by Dvsr
    Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
    I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
    After replacing the caps I started testing out the speaker. It seemed...
    09-10-2025, 10:20 AM
  • mkdj
    Lenovo Thinkpad L480 : 3VALW rail shorted to ground, but I can't find the shorted component
    by mkdj
    Dear all,
    Laptop is Lenovo Thinkpad L480 (boardview can be found in this badcaps topic). When pressing the power button the LED power light turns on, but nothing else happens.
    I removed the motherboard, checked for shorts on the main inductors. I found that there is a short to ground on the +3VALW_P rail (@PL201). I soldered a wire on the PL201 inductor, and I injected up to 1.3V with my power supply. Current drawn is approximately 3.2A.
    I used a small thermal camera to locate the shorted component. But nothing on the board heats significantly, except the...
    08-11-2025, 04:55 AM
  • guizmo1967
    Dell Latitude 5501 LA-H181P shorted power rail
    by guizmo1967
    This is my problem:
    Laptop: Dell Latitude 5501
    Motherboard: EDC51 LA-H181P
    I have two power rails shorted to ground, +1.0V_PRIM and +3.3V_ALW_PCH. I removed solder on PJP302, +1.05VALWP (pad1) not shorted but +1.0V_PRIM (pad2) shorted.
    I also cleaned PJP38, pad1 not shorted, pad2 (+3.3V_ALW_PCH) shorted to ground.
    I measure the resistance of all the coils on the motherboard and they all were not shorted to ground except coil PL301 before I removed the solder on PJP302.
    I injected +1.05V - 2A...
    07-25-2023, 06:56 PM
  • Askic
    TVS diode shorted on HP motherboard
    by Askic
    Hello guys,
    I have seen a few videos on youtube about repiring HP 15 pavilion laptops that has TVS (Transient Voltage Suppressor) diode shorted to the ground.
    Please have a look at the attached picture.
    The diode is P4SMAJ20A and according to the datasheet its breakdown voltage (at 1 mA is 22.2V or 24.6V at10 mA).
    THis means that if voltage goes higher that 23V this diode will start conducting and short to ground thus protecting rest of the circuits from overvoltage.
    What I don't understand if is this diode reversible, for example if voltage goes below 20...
    12-30-2020, 11:56 AM
