Samsung ln37a550p3fxza
  • 2old2
    • Feb 2016
    • 7
    I am a retired electrician trying to fix my niece's tv. Her house was struck by lightning. They lived with it cycling on off for awhile. I replaced several distorted caps. When the TV is plugged in standby light flashes, blue indicator comes on in front, chime sounds and backlight comes on for about 5 seconds. I have read through many posts and have gleaned a lot of good info. I tried resetting the eeprom which is on the front of the main board and it makes no difference. From my power supply CMN802, I have 4.1 vdc on pin 1 and the same on pin 3 st-by. I notice no drop in voltage when I hit the power on. The other voltages at that plug are where they should be. On CMN803 I have th 24v on pins 1-5, A/D 3.5 with BL on/off & PD with 0 v. I can disconnect connectors from the main board and jump 1 & 3 (CMN802) and 1 & 5 (CMN801) and turn the backlight back on. Where do I go from here?
  • sordids999
    • May 2013
    • 2161
    Re: Samsung ln37a550p3fxza
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • cliff_hootarski
      • Jul 2006
      • 411
      Give us a good focused picture of the back of the main board. These "A" model main boards need C102 replaced.
      • 2old2
        • Feb 2016
        • 7
        Hope this shows up clear enough.
          09-07-2024, 05:50 AM
        • Asraf Atb
          by Asraf Atb
          01-27-2025, 05:02 PM
        • JSin21
          Compatibility of main boards between different variations of samsung MU6100
          by JSin21
          Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
          I have Samsung Smart TV UA65MU6100WXXY version DA01
          Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
          11-27-2023, 04:54 AM
        • mrautom8
          Samsung TV UN75H6350AFXZC main board schematics?
          by mrautom8
          Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
          Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
          While relay is on, all voltage rails are present and steady (scoped) on main board.
          I love a good logic puzzle but getting lost without any schematics.
          No shorts on ANY capacitor main board.
          Thermal camera shows 3.3V inductor getting warm instantly but...
          10-19-2025, 06:32 PM
        • Yanleb
          Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
          by Yanleb
          Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
          If they are not compatible why did Samsung give them the same part number to begin with?
          08-04-2025, 11:35 PM
