Sharp VCR VC-M331SM(SS) repair, doesn’t turn on (in cold state)
  • Chungalin
    • Jul 2014
    • 423
    • Spain
    This old Sharp VHS VCR didn’t start after being unplugged for some months. It turned on after warming up naturally (long time) or shortly after forced warming with hot air on primary side of Switching Power Supply.
    Primary controller is IC902, a Panasonic AN8027, and switching mosfet is a SanKen 2SK2848. When SPS starts working you can clearly hear a subtle and characteristic *click* coming from the IC (or the mosfet? I’m not sure) and fluorescend display shows "SHARP".
    Just replace primary small caps C913 (22uF/50V) ) and C914 (10uF/50V), both related to feeding IC902. Now it powers on at once, even in cold state. BTW, both show a normal ESR of 1,1Ω and only capacitance is slightly degraded.
    Everything else is fine (tape mechanism, belt, roller, video output, secondary caps...).
  • redbaron1007
    Liquid damaged macbook A1466 fan spins, but doesn't turn on.
    by redbaron1007
    I got a tricky one today in the form of a macbook air A1466 820-00165-A that will recognize the charger and turn the light green then back to orange and the fan will spin constantly, but the system won't power on. The screen never turns on, it doesn't make the bong noise it's supposed to, and pressing the power button doesn't do anything. When I took the board out to visibly inspect it I only found one spot of corrosion on the bios IC. I pulled the chip, cleaned it and the area with IPA and put fresh solder on both and put the bios chip back on, but when I went to test it again it still does the...
    10-24-2024, 05:45 PM
  • melvinvdb
    Lenovo y520-15ikbm most of the time doesn't turn on
    by melvinvdb
    I've repaired a few laptops in my life but this time my own laptop died😂.
    Funny enough this one is a bit tough on me.
    It doesn't turn on (most of the time).
    Model: Lenovo y520-15ikbm (NM-391).
    The only way to make it turn on is:
    1) unplug battery + charger + rtc (seems irrelevant)
    2) wait a minute
    3) plug battery/charger in
    4) on charger plugin, laptop turns on by itself. On battery plugin you have to press power button. Sometimes nothing happens and you have to try again.
    5) when it turns on it also displays POST...
    08-15-2024, 12:28 PM
  • Victor Petrovich
    Lenovo IdeaPad 3 15ITL6 doesn't start
    by Victor Petrovich
    I have laptop Lenovo IdeaPad 3 15ITL6 with Intel Core i3-1115G4. When I press the start button, LED light on the start button starts blinking 12 times, then stops and after some time starts blinking 12 times again. When it stops, all voltages are down.
    The motherboard is HS460 HS560 HS760 NM-D471 Rev: 2.0
    S/N: PF3Q0WTF
    The motherboard is not mine, also there were corrosion on the board which I cleaned.
    Methods of fixing like fully turning off the motherboard or starting only with adapter doesn't work. All testing were did only with adapter on.
    06-07-2025, 02:40 AM
  • ttmi100x
    HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
    by ttmi100x
    Greetings everyone,
    I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
    The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
    Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
    Upon closer inspection...
    07-31-2024, 06:36 PM
  • Davi.p
    Sharp LC-40LE924E doesn't enter service mode
    by Davi.p
    Theese Sharp series with soft touch border keys have a serious bug with standby software, i have followed surely well the serv. manual instructions, tried many many times, tried many variants, no luck, i've also tried to erase the main settings eprom first, and the the standby eprom.. no luck, with the second the TV did not turned on.. if anyone have found the right trick i thank him..
    03-07-2021, 01:23 AM
