I picked up this 42 inch Samsung PN43E450A1FXZA plasma that has no picture. Low voltages are fine Vs and Va peak up to correct voltages for several seconds then decay down to under 10 volts. Isolating all boards from SMPS made no difference. Red power light flashes after startup chime sounds. At this point I am suspecting the power supply board and ordered one. Any suggestions are welcome.
Samsung 42 inch Plasma - Sound chimes no video
Re: Samsung 42 inch Plasma - Sound chimes no video
More likely there's a couple of IGBT's short on the Y-SUS board or maybe buffer-chip causing trouble.
--Remove buffer-board and retry with everything else connected...
If the psu gives Vs/Va for some seconds--Doubt its that causing trouble... Its being shut-down by cont/mainboard due to fault condition, usually in the sustains or buffersLast edited by Alastair E; 02-05-2016, 01:40 AM.TELEFIX
PLEASE DO NOT EMAIL ME PRIVATELY FOR REPAIR ADVICE. QUESTIONS BELONG ON THE FORUM! -
Thanks for the tip! I will certainly give that a shot. This model has one huge Y buffer board so it will be an easy test. I suspect it may likely be that since isolating the Y-SUS did not fix the fault. Although a quick tips guide I found in Tom's library said that Vs is generated on the Y board in some fashion. so it may still be y-SUS related. I'll report back after further testing.Comment
Alastair, you were right! My $13.00 SMPS did not fix the issue. I will try pulling the buffer next to see Vs comes up stable. The good news is that boards are pretty cheap for this entire set! So worst case, I have an extra power supply...Comment
Also, one interesting note: When testing the one of the IGBTs in circuit on the Y-SUS board, it did not switch off abruptly as a normal test would indicate, but the LED on my test jig did a slow "decay" to off when i turned the gate voltage off. This could be something else in circuit but I found it to be odd ?Comment
Pulled the buffer board and same results: Vs Va both jump high to normal and decay immediately to almost 0. I tried the main board isolation test by removing the power connector at the main board and jumping the power_on pin to ground pin. No luck. Should have given me a test pattern but same drop in Va Vs occurred. I am now focusing on the YSUS board with testing.Comment
The SMD code is actually "87" and the package is SOD-106. I have another thread going to track this down in the general topics forum, but no luck so far. I believe he answer maybe in "Turuta SMD Databook 2014" if anyone has a copy and could check.Comment
RFN2L4S
400V 1.5AComment
So, sometimes a wild goose chase ends with the Golden Egg goose! On my efforts to repair YSUS board # LJ41-10136A, I found diode D5126 with SMD Code 87 was in fact the 400V 1.5 Rohm diode. However, when i pulled it out, it tested OK out of circuit. So, a little further investigation revealed that it was paralleled across Q5017 an IGBT (FGD4536) (1st image). I tested the IGBT and found it was shorted! Just so happened I had several of these from another project. I soldered D5126 back in place and replaced Q5017. Bingo! Diode test across D5126 now read OK. So I put the Y-SUS back in for the 1st smoke test. As before startup chimes, but no video. Voltages still spike then fall off right away, same as before.
At this point I assume the new IGBT is fried, so I pull the board for more testing. But Behold..It's OK.... hummmm.Last edited by smartjohn; 02-20-2016, 03:15 PM.Comment
probably need to go deeper and look at all the devices around it including driver ICs , smaller SMD parts like resistors, transistors, diodes.
Only 1 shorted IGBT, ?
I think given the cost of a whole board s it worth it? Hows the Xmain? Gone over that?Comment
Again, a little more investigation revealed another fault. Q5016, another IGBT (IRG7R313) appears to be shorted. But looking a little further, I see it is also parallel with a larger diode pack D5014 (F10A400HD) a 10 amp, 400Volt TO-252 device (see Image). So not to be fooled again, I un-soldered only the the collector tab of Q5016, and it tested OK. So this time IT WAS THE DIODE !! HA!! D5014 tested 300 ohms in one direction, and about 600 ohms the other. I did not have another F10A400HD laying around, but I did find a suitable diode for just for testing, an FSU05A40, 400Volt 5 Amp diode. This is not my permanent fix BUT ONLY for TESTING! I ordered an STTH10R04G-TR from DigiKey as the permanent fix.
Bottom line IT WORKS !! to summarize the fix: Q5017 (IGBT FGD4536) was shorted and D5014 (F10A400HD) was shorted. A couple of $2.00 parts max and I’m up and running. Thanks to all that helped me track down the diode that was not bad, but eventually led me to the answer.Last edited by smartjohn; 02-20-2016, 06:59 PM.Comment
Bottom line IT WORKS !! to summarize the fix: Q5017 (IGBT FGD4536) was shorted and D5014 (F10A400HD) was shorted. A couple of $2.00 parts max and I'm up and running. Thanks to all that helped me track down the diode that was not bad, but eventually led me to the answer.
Nice workComment
Please help!I need to now what numbers are on the resistor R5052 and R5053. I am working on a faulty board LJ41-10136A and those resistors are burned and I need the value to change them. I bought the other components but I don't know the value of this two resistors, are they 101?They are in the proximity of MOSFET Q5024 and Q5025.They have connections with OP 5007 wich is also defective and I must replace him.Thanks in advance for who want to help me.Last edited by NIGHTWHISPER68; 07-04-2017, 02:56 PM.Comment
Dunno, good luckComment
Hello .The resistors where 222. I finished adjusting the board .Everything is working!I changed: two MOSFET 5N50, one IRG7R313U, one optocoupler P155E, two resistors 105, and two resistors 222, one capacitor 105 -1kv and the tv is back to life!To forum member tw2005 again many thanks!Comment
Bottom line IT WORKS !! to summarize the fix: Q5017 (IGBT FGD4536) was shorted and D5014 (F10A400HD) was shorted. A couple of $2.00 parts max and I'm up and running. Thanks to all that helped me track down the diode that was not bad, but eventually led me to the answer.Comment
Bottom line IT WORKS !! to summarize the fix: Q5017 (IGBT FGD4536) was shorted and D5014 (F10A400HD) was shorted. A couple of $2.00 parts max and I’m up and running. Thanks to all that helped me track down the diode that was not bad, but eventually led me to the answer.Comment
by gl4709I am working on a Samsung un55cu7000d which has backlights and audio. There is no picture. This model does NOT have a separate TCON board. Before I order a main board I would like to try and confirm that the issue is not in the display. The ribbon cable from the main board goes directly to the display and I can then disconnect the left from the right. When I disconnect the right side the display lights up on one side but has no video being displayed. Can you all give me some guidance on how to confirm the main board is the issue.
by Max514Hi all,
Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
- Unplugging the main board cable at the power supply >>> backlights came on.
- BLU_ON signal from the
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by soerenI am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
All happened after the battery ran out of power overall several days when I was on vacation.
I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery... -
by willis6732The customer of this TV Heard a pop sound before it went dead.
The VS and VA voltages turn on imediatly and then slowly die off.
I got a replacement Y-Board (Large board on the left) from aliexpress and still no luck
If tested all the IC chipson the board all the way on the left by running meter along the connectors and couldnt find any shorts there...
I think ive checked most the capacitors for shorts as well as most of the diodes and mosfet/transistors on the big boards.
https://photos.app.goo.gl/KDyLcgB38Bh699Zr6
... - Loading...
