Samsung 32" LCD TV le32R86 BN41-00813e BN94-01472K
  • LPs1978
    • Jan 2016
    • 8
    • Italy
    I'm trying to fix my LE32RB86 LCD TV.
    I changed all caps on the power supply board but the TV still has problems.
    When the TV is cold it takes 20 minutes to start before correctly shown the image. In this 20 minutes what you can hear is just noise and the red led continusly blinking and the blu light under the samsung brand switching between on and off.
    What I understood is that if I heat the CPU board with an hairdryer the TV starts quite immediately.
    Do you have any idea about what I can check on the CPU board?
    I attach some picture of board.
    Thanks,
    Luca
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Samsung 32" LCD TV le32R86 BN41-00813e BN94-01472K
    On the Mainboard--
    (Assuming its a Bordeaux-Plus)--marked on the top by the universal interface socket
    There's a Large tin box. (NOT the one with antenna socket on,--The other, larger one) You'll need to remove the cover, and under there next to a large processor-chip, there's two smd 1000uF 10V caps. Cant miss 'em they are the only two 1000uF inside that box.
    --These will need replacement.
    I use standard through-hole parts, usually Chemicon or Rubycon low-impedance types 16V 1000uf to replace.
    You Have to refit the tinwork cover--as it forms the heatsink for a few chips, so the caps need to be laid down by side of the chips, or use proper smd low-impedance or poly/os-con caps....
    TELEFIX
    • LPs1978
      • Jan 2016
      • 8
      • Italy
      Originally posted by Alastair E
      On the Mainboard--
      You Have to refit the tinwork cover--as it forms the heatsink for a few chips, so the caps need to be laid down by side of the chips....
      Thank you.
      I'll give it a shot and I'll be back to you.
      • LPs1978
        • Jan 2016
        • 8
        • Italy
        On the Mainboard--
        Thank you. I changed both 1000uF caps and all is ok now.
        • jiMacOS67
          • Feb 2017
          • Greece
          One more THANK YOU!
          I have a LE32R86 with noise in screen and sound for 5-10 secs when power on.
          Thing got worst by time.
          I changed the capacitors on power unit.
          No result
          until
          I read your post!
          I change the caps in the CPU board and everything is ok!
          THANKS again!
          Dimitris
          • kourkouras
            • Feb 2018
            • greece
            On the Mainboard--
            I had a startup problem, like snow and made 3-4 reps until the TV was working properly, I changed the 2 1000μf / 10v capacitors that are next to the cpu and all OK. Thank you very much .
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • ohren
              Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
              by ohren
              I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
              I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
              The models launched in 2018 and 2019 respectively....
              09-08-2023, 05:24 PM
            • C152Heavy
              Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
              by C152Heavy
              Summary for TL-DR readers:
              • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
              • Have obtained Samsung schematic & service documents - Can upload if helpful.
              • Have read ALL applicable threads
              • C1818 and CP820 replaced as low hanging fruit
              • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
              • VCC pin (18) of PFC...
              01-11-2023, 02:53 PM
              09-07-2024, 05:50 AM
