LG 60PB5600 Plasma Won't Turn On
  • SpeedAddiction
    • Jan 2016
    • 21
    • US
    I think I've narrowed down the problem but wanted to run it past everyone first to make sure that I'm not missing something.
    The TV initially fell victim to a very close proximity lighting strike which left it with the inability to turn on and unsightly PSU / Main Board burns. After swapping both boards out it still refused to turn on.
    So after extensive reading of these forums and troubleshooting I have the following results.
    With P231 Unplugged from CTRL Board and EXT_AUTO_GEN jumped along with RL_ON / 5.2 jumped on the PSU the TV sprang to life in test mode.
    This should point to the Main Board being bad but since it was just replaced with a Main Board from ShopJimmy.com I wanted to make sure it wasn't the Power Button / IR Receiver. Checking Voltages from p501 connector on Main Board while hitting Power on TV and remote showed the following.
    1 - 0
    2 - 3.25v
    3 - 3.25v
    4 - 0
    5 - 3.21v
    6 - .203 (I think this is with the MM since VS TP tested the same way)
    7 - 3.20v - Jumps all over when hitting the TV power button
    8 - 3.20v
    9 - 0
    10 - 3.14v - Jumps all over when hitting the remote power button
    So, does it look like the Main Board? Anything else I should test before I claim it's bad?
  • SpeedAddiction
    • Jan 2016
    • 21
    • US
    Re: LG 60PB5600 Plasma Won't Turn On
    Does anyone have any additional input or tests I should try out?
    • Hamie
      • Apr 2014
      • 1383
      You have a faulty mainboard.
      Shop Jimmy are not immune to selling duff parts as many on here will testify to.
      • SpeedAddiction
        • Jan 2016
        • 21
        • US
        Great. Thanks for the confirmation. MainBoard going back.
        • PNI E.
          Samsung ue55tu7170u not turn on and no standby led main bn9650990e
          by PNI E.
          Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
          03-17-2025, 04:23 AM
        • bffargo
          2014 LG 60" Plasma shut down just clicking unless I disconnect 17V line to main CPU
          by bffargo
          LG 60PB66550 NOV 2014
          PSU: EAY63168603
          PCB: EAX65359531 2013.11.01 Rev:1.0
          Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
          Symptom:
          While watching, just went black and started clicking relay every few seconds.
          Initial diagnosis:
          Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
          Deeper diagnosis:
          Pulling pins #1/#2 (Blue/Grey) from the connector housing...
          09-09-2022, 07:34 PM
        • cheeky2
          by cheeky2
          05-25-2024, 03:27 AM
        • bcstedt
          Samsung PN50C540G3FXZA 50" Plasma, power cycling, Y-Main problem, Canada
          by bcstedt
          Just starting to crack into this one and wanted to get the ball rolling.
          At power on (plug in), power light on, relays click, repeat (sometimes)
          After disconnecting Y-Main from SMPS power stays on and boot up jingle is heard from speakers
          Removed Y-Main for inspection and testing
          This pic from:
          PN50C540G3FXZA Fast Track Troubleshooting Manual - Rev 1/10/12
          12-15-2023, 10:30 AM
        • Dani_2024
          by Dani_2024
          10-28-2024, 05:06 PM
