Samsung LA40A650A1F no 5.3v standby
    Re: Samsung LA40A650A1F no 5.3v standby
    You can use through hole resistor in place just for testing.
    • maxvalutech
      • 804
      • australia
      OK I found a 10k resistor and bridged feed resistors 2 and 3 so dropping voltage thru 14k rather than 12k and we now have a red standby light. But when on is selected the light goes out the single fan gives a kick the light gives a blink and comes back on so something else yet to be found. Have some 1000uf 25v caps coming so will put those in and then see what happens
      Voltages measured cold side 22v main 5.1v standby.
      • maxvalutech
        • 804
        • australia
        To bring up to date: after replacing caps must have moved resistor I had soldered onto bottom side of board - it shorted out after about 5min and blew fuse plus what else - red standby gone! But I had meanwhile got onto another power board (from Poland no less!!) and now have standby again. Activation gives red light blinks slowly about 4times then quickly - one time only did see very briefly screen light only a split second. Main board problem now ???
          So what DCV do you have on the connector pins of the power supply board that goes to the main board, all ZERO VDC except the STBY 5V?
          • maxvalutech
            • 804
            • australia
            That's right.and when power on is activated get the 13v up plus 5.1v the fan runs but no start otherwise.
            • maxvalutech
              • 804
              • australia
              #26
              Later to above can now get backlight to stay on with red light continuing fast blink.
                Hmmm.
                • maxvalutech
                  • 804
                  • australia
                  #28
                  Have connected AV2 input playing VCR and the remote causes screen to blink when using buttons such as menu and source but nothing shows up and red light continues rapid blinking
                  Almost there just the last step does not complete due to ???? I note again standby blinks 4 times before then rapid blinking which doesn't want to stop despite many inputs including power off but does eventually stop. Also no clicking sound ever - should there be??
                  • maxvalutech
                    • 804
                    • australia
                    #29
                    Not being au-fait with these sets I do note that the touch sensitive buttons on front of set appear to work but do not light up at all. Of course the set has not fully turned on but....??? Took the tcon board out all looks OK and 13v seen on that board. Tried heating all boards no go.
                    • maxvalutech
                      • 804
                      • australia
                      #30
                      This saga continues. From the owner I have determined that 4 red light blinks before start is normal. Also that the set was a factory second. In this regard I noted that one of the power boards 1000uf caps had been replaced, a fan fitted above that area of usual trouble and a screw missing from main board all of which indicates work done to try rectify the badcaps problem before sale. I have fitted all new caps to the power board and confirmed all voltages ok. Redlight continues fast blinking so i have now tried to identify eeprom to do a reset - no luck!!! And cant find a schematic for bn41-01022d. Do have same board from 32" model but different stick on tag number and a number of circuit differences. Will try get reasonable pics of board - do note one ic has lcd printed after its number And another is numbered ic1111 which doesn't seem to relate to any others - can't read anything printed on the ics.
                        09-07-2024, 05:50 AM
                      • tvguy12012012120
                        by tvguy12012012120
                        02-07-2025, 05:13 PM
                      • ChristianBr01
                        LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                        by ChristianBr01
                        I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                        The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                        What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                        04-23-2025, 01:48 AM
                      • Kaar3l
                        Samsung QLED QE65Q7FNAT only standby light
                        by Kaar3l
                        TV: Samsung QLED QE65Q7FNAT
                        PSU: BN4400940A
                        MB: BN94-12832K
                        I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                        09-24-2024, 01:35 PM
                        09-06-2024, 11:40 PM
