Sanyo Dp50843-00 Power On Issue
  • lordsecs
    • Jan 2016
    • 5
    above Model when plugged in no indicator lights (Standby or Power) Set appears to be dead. All voltages on PS are correct. If I press the power button once and walk away the set will come on in 5 to 10 min and work normally. What am I missing?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8325
    Re: Sanyo Dp50843-00 Power On Issue
    Here is a WAG: take freeze spray or a can of air upside down and freeze the EEPROM on the main board. Then turn the TV on. See what happens.
    • lordsecs
      • Jan 2016
      • 5
      I have already tried that plus heating the eprom. No change. I don't mind ordering the main board if this is the problem.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8325
        If you haven't heated up the capacitors on the main board already, I guess it's time for a new board.
        • lordsecs
          • Jan 2016
          • 5
          Replaced EPROM $15.00 Working Great now
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8325
            thanks for the feedback!
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
            • justice171
              Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
              by justice171
              I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
              Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
              1. Verified that all critical voltages are present:
                • 3.3V and 5V are always present if DC is plugged.
                • 1.8V on the BIOS chip is present.
              2. Checked the power button functionality:
                • When pressed, the voltage drops to 0V, indicating the button is functional.
              3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                • Confirmed connectivity is intact, ruling out issues
              11-26-2024, 12:39 AM
            • claws77
              lenovo flex 5 14itl05 power sequence issue
              by claws77
              hi guys, my motherboard will not start no matter what
              when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
              but rest nothing happens no sign of life.
              this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
              with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
              but now nothing happens no matter how much i wait/ charge/ press and hold power button.
              i have no knowledge of motherboards ....
              10-20-2024, 02:48 PM
            • yaya3gmax
              Laptop Power Issue – Works on Battery, Fails on Adapter Load
              by yaya3gmax
              Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
              Symptoms:
              • Laptop works normally on a pre-charged battery.
              • Battery does not charge when adapter is connected.
              • Without battery:
                • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
                • Speakers “pop” when power cut occurs indicating harsh sutdown.
                • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
              08-21-2025, 07:16 AM
            • SuperJames
              Dell G3 17 3779 Weird power cycling and shutdown/restart issue
              by SuperJames
              This one's a weird one, and still unsolved despite it having gone back to Dell once.
              Specs
              i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
              Backstory
              I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
              10-23-2023, 04:09 PM
