Hi Everyone. Glad to have found this forum. I have a Samsung 27 inch LCD TV having board BN44-00208B like this - http://g03.a.alicdn.com/kf/UT8NiuJXa...b1c1e34ee6aae5
To be honest I am 'wasting' a lot of time to find the fault but I hate it to just throw it away because buying a new one is not that expensive.
The problem seems to be the power supply. It has no standby power. I changed all the 6 low voltage caps and the bridge rectifier.... they were all good but just in case. There is no DC power on any pin which connects to the Main Board. The main capacitor charges to around 680 volts. A good look at the board shows no signs of damage. If it helps, the TV worked fine till one day I did not switch on, ie: the damage happened whilst switching it on.
What would you look at next? Also any advice how to check these components...
Schottky Rectifier SBRF 20100CT - http://www.datasheetlib.com/datashee...html#datasheet
Schottky Power Rectifier MBRF1545CT - http://www.datasheetlib.com/datashee...rporation.html
They both have 3 legs. None seems shorted but not sure what these are (Transistors / Semiconductors ??) and most importantly how to test them with a multimeter. When checking the SBRF 20100CT (which seems a PNP) I get .8v forward voltage and around .3v reverse. Is this normal?
Any help is appreciated. Thanks a lot.
Mario
Mario
