Panasonic TH-P50U30A 7 blinks
  • tw2005
    • Oct 2011
    • 6458
    Panasonic TH-P50U30A (Tc-P50S30) advertised as 7 blink bad P and SC boards.
    Anyway one of these ones you wonder why you take on as it's one that has already been messed with.
    First thing I notice, bridge rectifier missing. and a FET unbolted and removed to test
    Rectified those issues and P board OK now.
    Next i jump onto the SC expecting it to be dead- nope, it's good which I'd rather have bad SC and good buffers so this will be expensive.
    SU is shot, quick check between Vfg and the outputs and there's shorts.
    Did the same on the SD and all ok normal. I get consistant 0.73 which is what I would nomally see.
    Totally removed the SU, jumpered SC50 still 7 blink, but ok with SD isolated.
    Puzzled I did the resistance measurements, SU was no surprise but the SD was.
    Results.
    SD,
    1 Vfo 5.8M
    2.Vscn_f 7.2M
    6. VF5V 29K
    SU
    8. Vfo 9.2ohms
    6.Vscn_f 238k
    2. VF5V 2.3ohms
    Resistance checks look all wrong except maybe SU pin 6.
    lets hope the panel is OK and I'm not about to blow a buffer set.
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TH-P50U30A 7 blinks
    Just popped the back off the GT30 I'm working on, resistances on the SD are close to what mine has?
    maybe although it says you can jumper Sc50 on the ST series and have the Sd pass , this ( U series) TV don't like it?
    Was going to try out the upper from this GT but I can't get the fingers in safely so I have a buffer set coming, don't want to tear the panel ribbons on the GT
    • tw2005
      • Oct 2011
      • 6458
      Just did 150km round trip, buffers I was getting both shorted
      Lucky for the seller , I tested them otherwise would have been an Ebay loss for them!
      • tw2005
        • Oct 2011
        • 6458
        Just removed the 1 IC on the Su which was shorted, threw the boards in and fired up, picture to the missing IC, but enough to get the serv tool up and this has done 5400hrs
        • tw2005
          • Oct 2011
          • 6458
          picked up another 7 blink 50U30A over the weekend. Yep, same problem , shorted SU board.
          Was hoping for a dud SC again, no joy. These TNPA5336 boards are hard to find or extremely expensive. I got lucky and found some from a ST30. Same board just has heatsinks and working perfect on this last TV.
          This one only has 3800Hrs, quite incredible the little use really these have had.
          • tw2005
            • Oct 2011
            • 6458
            now I know what's good I can confirm resistances using my fluke 73 with the red probe on the vfg plate.
            SD,
            1 Vfo 4.76M
            2.Vscn_f 7.79M
            6. VF5V 28.1K
            SU
            8. Vfo 5.52 Meg
            6.Vscn_f 9 meg
            2. VF5V 28.4k
            • jjanssen7
              • Nov 2012
              • 252
              thanks for recording this. Have worked on these and will do so again. These values are valuable!
              • tw2005
                • Oct 2011
                • 6458
                no worries, I like to collect and annotate whatever I can for future use. I have been assuming the figures would have been closer to the 2010 models but they're not.
                people will get differing results I guess depending on their meters but good to have some indicative examples.
                • flocko
                  • Nov 2012
                  • 1121
                  Hi TW hope the move went well, How are you doing on the buffer IC replacement . have got some more on order from China.I have replaced 8 on the trot ?I think I have the hang of them now, doing them by removing silicon then cutting the legs,low melt solder, clean pads off then take body of last with thin knife blade then clean up well, working for me Flocko
                  • tw2005
                    • Oct 2011
                    • 6458
                    Went well, thanks. Buffer replacement, you must be a mind reader. I'm just reaching the point where curiosity is getting the better of me. Was thinking of starting a thread asking if anyone was getting into this.
                    After my last posts i think it was ricosavy and have removed 2 more chips cleanly which is a good start has made me wonder if i should go to the next step.
                    have ordered a cheap hot air station and considering these boards need just 1 chip I'm thinking of having a go.
                    My question is how is the chip being fitted compared to what panasonic does with that heatsinking grey sealant?
                    That's my deilemma, what product is used to seal the pins that's suitable for the voltage?.
                    Got any photos of your work?
                    • flocko
                      • Nov 2012
                      • 1121
                      Will take photos when i do the next ones , I use Permatex 82194 ultra grey silicone i found someone on a US site that was using this, and the data form Permatex backed up my voltage and heat concerns . its sold as auto gasket, but has not been a problem in use. i do not use hot air just low melt solder run on the pins then wick off. when you fit do not drag solder as the pins will bend then you have to get them back on the pads, better to do corners then go pin by pin. IC are coming in at about £30.00 for ten from China
                      • tw2005
                        • Oct 2011
                        • 6458
                        As always, value the input but what about the fact that this sealant is acetic acid based which from what I've read is corrosive to the pins?
                        • tw2005
                          • Oct 2011
                          • 6458
                          maybe this?
                          • flocko
                            • Nov 2012
                            • 1121
                            I dont know were you see that? would think if that were the case it would not be much good as a auto gasket sealer for metal parts ? that is what i use and until I have a problem will continue to use, Flocko
                            • tw2005
                              • Oct 2011
                              • 6458
                              yeah, looks like i got mixed up then, looking again at the TDS, says it's oxime based.
                              Well that's worth a shot then I guess, easier to get.
                              • Nick's Tvs
                                • Jan 2014
                                • 621
                                TC-P50S30 7 blinks, with VS shorted to ground on SC.
                                Replaced all shorted components, and got the screen to prime, however the picture did not show aside from a few sparkles of red and maybe blue or green. I shut the set off fairly quickly after. I made sure all screws were tight, and all connectors were in properly. Tried one more time with the exact same result.
                                After further investigation, I realized that the previous owner had the brilliant idea to snap off the thermal fuse. So I went to shop jimmy to look at their picture and see what kind of rating it had and proceeded to replace the fuse.
                                After doing so, the tv went back into 7 blinks however the SC board is no longer shorted out, and all components replaced are holding.
                                I removed the fuse again to see if the panel would prime again, and it has not. It is stuck in the 7 blinks. Now I also went ahead and checked readings between vfg and sd/su
                                SD
                                1 Vfo O.L
                                2.Vscn_f 25M
                                6. VF5V 25M
                                So obviously I am doing something wrong here but not sure what.
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  I think isolate the sd/su including the 4 Vfg bolts and jumper sc50, powerup and see where yo're at if you have not done so .
                                  What thermal fuse are you referring to?
                                  Any pictures
                                  • Nick's Tvs
                                    • Jan 2014
                                    • 621
                                    Jumped at SC50 and I got the tv to stay on with about 219 volts on the VS line and about 124 at the VFG plates. So the repair on the SC is holding, and the tv is turning on without the SC and SS, however I still don't have that thermal fuse on the board which is confusing as to how its working with out it.
                                    So that thermal resistor I am talking about is the white one labeled
                                    5w 2.2ΩK 133 on the picture attached. It is located between the 2 connectors to the lower buffer and the 2 center vfg plates
                                    http://assets.shopjimmy.com/media/ca...c1mnux-top.jpg
                                    I had placed one in between where the original leads were cut off but it was removed for the SC50 test. Please see picture attached for what I actually have in my set up.
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      R515, 2.2ohm 5W ceramic needs to be there. have you looked at the schematics?
                                      there was nothing in the photo except a vacancy, I had to look at SJ to figure it out.
                                      • Nick's Tvs
                                        • Jan 2014
                                        • 621
                                        Yes that is what I was pointing out, the previous owner of the tv tried to fix the set by cutting out the ceramic resistor. I had no idea that he had opened up the tv himself and did that until I tested the tv after fixing the short on the sc board.
                                        What voltages should I be expecting on the VFG plate? I will go ahead and place the resistor back on there from another board and test again for voltages.
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                          11-20-2024, 08:52 PM
                                        • Biruslapio
                                          Panasonic P58V11B 8 and 12 blinks error "fix"
                                          by Biruslapio
                                          Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                          Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                          04-13-2021, 07:13 AM
                                        • jm1234
                                          Panasonic plasma TX-P42ST50 - 6 blinks
                                          by jm1234
                                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                          I checked that board for any obvious faults...
                                          05-22-2024, 06:59 AM
                                        • Alicat
                                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                          by Alicat
                                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                          Model number is TH-50PZ85U
                                          Power comes on and the red power light stays on solid.
                                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                          I also hear a few clicks.
                                          I also think my parents said there was a thunderstorm and the TV failed after that.
                                          Section 6 in the service manual talks about power and no screen,...
                                          10-30-2024, 10:09 AM
                                        • CrewmanRedShirt
                                          Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
                                          by CrewmanRedShirt
                                          Hello all,
                                          As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
                                          07-13-2024, 11:02 AM
