Sams. 50Q97HD --No Sound...
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    After replacing the X-SUS we got the set going only to find no sound--not a bit. Picture is fine and DVB retuned no problem Ive not tried any different inputs such as HDMI etc yet.
    Checking through the sound settings, the only two available for adjustment/alteration are AVL -on or off and SRS -on or off.
    All other options greyed out, but says Internal speakers are on.
    Must be doing summit silly--just can't think straight tonight....
    TELEFIX
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Sams. 50Q97HD --No Sound...
    Maybe a factory reset ? Had a Le40r88 (I think) no sound after reset worked fine.
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Tried a reset, no change.
      Tried the mainboard--bunged a 42" mainboard in, expected and got half a picture--but Still no sound....
      Checked all the supplies from PSU, all fine....
      Turned out to be the bloody headphone-socket switch faulty!
      TELEFIX
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Lol easy fix
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Probably just got dust in the Aux jack.
          • Alastair E
            Chief Womble
            • Mar 2013
            • 1963
            • U.K.
            Aye--Probably, I'll get to that when I fix the PSU from 42Q96 I robbed the side-input board from!
            TELEFIX
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Haha fair enough btw what work you going to do on this ? Make sure to:
              Recap Y and X main 680uf 25v caps even if they test good
              Resolder all heatsinks and joints on the Psu
              Recap Psu (most output caps)
              Maybe add a fan to the Ymain only if it uses the horrid 88N30W fets which are prone to blowing on these
              Heatsink all buffer Ic's
              This is just some of the mods I do on these so much to go wrong. Got another 50PFP5532D/05 which is basically Q97 got alot to do on it lol
              • Alastair E
                Chief Womble
                • Mar 2013
                • 1963
                • U.K.
                Strangely--This Q97 has only 350 hours on it!
                It was spotless inside, but the X had failed and I had a good clean spare, so fitted that.
                What I find with them--inc this one, is the mounting screws on all/most of the big transistors of Y and X are usually loose....
                I had one a while back that had been running for half hour or so after a PSU repair--the heatsinks of Y-SUS were oddly cool.
                Tightening the screws--It got the expected temperature!
                --That one in 'Pangoo' guise I sold to neighbour a year or so ago, still running well, outlasting a new 50" 'Laurus' Vestel turd, that his dad wrecked with the wrong stand-screws--Straight through the T-Con!.
                TBH--I usually use 35V 1000uF to replace those troublesome Y-SUS caps--And the one on the X top l/h corner that everyone forgets about....
                Once sorted, these ain't bad old sets, good panels in them I find.
                TELEFIX
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Wow 350 hours how odd lol never seen one with them screws loose slightly odd so will look out for that in future. These panels are rock solid only seen 2 fail and both were because of the people who I used to work with were (and still are) useless at repairing Tv's and broke the ribbons off lol and that was when I couldn't repair them ribbons.
                  Too bad the scan and other driver electronics are not as reliable as the Pdp's themselves these could last along time.
                  My theory on why these fail alot is because of Shitsung's (Samsung) engineering these Tv's need fans ffs ! They run so hot, Psu is dissipating 400w idle and more under load they get soo hot its scary, enough to be painful to put your hand on top after running for a while !
                  • Alastair E
                    Chief Womble
                    • Mar 2013
                    • 1963
                    • U.K.
                    I believe this is a problem with a lot of sets-- Heat.
                    I have a Panasonic TX-P50G20 at the moment, that thing gets hot--Or did till I added some extra case fans on the top, opened up the bottom of the rear cover and added a couple to the SUS boards, with extra (Big old L.G. IPM) heatsinks toaded across the original Y-SUS heatsinks...
                    Thing's practically is stone cold now....
                    Even the LED types, the actual power-parts can run pretty damned hot in some, no wonder they have a short life.
                    The price we pay--For Cheapness.
                    Like the LED's themselves. Have you ever put your finger on one without the lens fitted and its on?--Dont! It'll burn you! The package size for those TV backlight LED's specifies they are rated at 0.2W and should be heatsinked, guess they rely on the board copper, but then stuff it all up by overruning them!!....
                    TELEFIX
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Yep, odd thing is my Pioneer kuro 428XD Plasma from 2007 even after about 6 hours of constant use watching Tv barely is warm, Psu is the hottest part. There is only one fan in my Tv which is over the Psu lol the Sus boards in Kuros barely get warm which I find odd I also serviced a PDP43MXE (or whatever) and it didnt have any fans ran as cold as anything.
                      But seriously these Samsung Plasmas need fans if they flipping added them they could live at least 5* longer than they do.
                      Also with Led's ive done it and paid the price for it lol burnt finger. Leda also need alot of heatsinking big time they run hot ! I have a customer built Led lamp which I use as a light it has several strips of Led's I have heatsunk it but wow that burns your finger after a while lol. Check this out:
                      https://m.youtube.com/watch?v=JQjCOH1Robk
                      • ChaosLegionnaire
                        by ChaosLegionnaire
                        09-13-2022, 09:02 AM
                      • LEECH666
                        Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                        by LEECH666
                        Good day ladies and gentleman!
                        I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                        This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                        I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                        01-19-2024, 05:46 PM
                      • Christos Tsiligiannis
                        Marian Trace Alpha sound card repair help
                        by Christos Tsiligiannis
                        Hello to the forum.
                        My name is Christos, I am new to the forum here and i am posting from Greece.
                        So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                        To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                        So i tried asking for a schematic from the company and they would not give me one. Instead they...
                        11-18-2024, 05:26 AM
                        HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
                        This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                        09-12-2024, 02:30 PM
                        HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
