RCA L32HD31 - Power led indicator but no display
  • caphair
    • Nov 2011
    • 1249
    Re: RCA L32HD31 - Power led indicator but no display
    Sounds good ill run it like that and let them inform me if anything happens.
    I'm curious what did that fuse control? I'm having a hard time understanding the circuit. It looks like it went to the feedback of the ic, but the primary winding has two different windings. Are they both being run separately?
    Here's the link to the schematic
    https://www.badcaps.net/forum/attach...6&d=1375893777
      The fuse is just the protection for the power supply for the PFC and the SMPS ICs. Looking at the BOARD layout, it looks like it used for powering the PFC controller IC and the SMPS IC for the 12V/24V through switched Transistor Q11 which is turned on (by OPTO IC6-B which is turned on by transistor QS3) by PS-ON signal to the Base of QS3 (Q12 is setup as 12V linear regulator to supply VCC to the 2V/24V SMPS IC).
      The same AUX winding of the standby transformer is also fed to the other diode D82 for running the STBY IC once the circuit started up.
      If you look at most of the power supply for TV, the power supply for running the PFC and other SMPS section is generated by the AUX winding of the STBY Transformer through a switched device..
      • caphair
        • Nov 2011
        • 1249
        Ah ok. Thing I'm stuck on is the AUX winding. How is it producing a separate signal from the primary winding? I'm thinking in simple terms how a transformer works. Primary induces voltage in secondary
          The STBY transformer has one primary winding where the drive is applied, and it has two secondary windings, one for making 5V, and another one for making the VCC for running the SMPS IC.
          Transformer can have more than two windings (primary, secondary) depends on how many outputs you want from the transformer,there are many form factor for the transformer windings.
          http://www.edn.com/electronics-blogs...power-supplies
          http://jandkaudiodesign.blogspot.com...ansformer.html
          • caphair
            • Nov 2011
            • 1249
            Ok but my confusion comes from seeing it on the schematic, it's showing the AUX on the primary side and in the circuit it's not on the secondary side of the board along with the 5vsb
              The location of the winding in the schematic symbol can be made any way you want, in this case it is on the left to make it easier to see what this winding is being used for.
              • caphair
                • Nov 2011
                • 1249
                #27
                Ok but even on the board it's how it looks in the schematic. So they can make a secondary side on the same side as primary?
                  That AUX winding is being used in the dc primary side of the circuit to supply the voltage to run the SMPS ICs in the primary side, that is all so the two pins of the winding is located in the hot side of the circuit this will allow it to pass creepage/clearance for safety compliance testing..
                  • caphair
                    • Nov 2011
                    • 1249
                    #29
                    I see. So are there two separate windings on the primary sharing the same core but only one is being pulsed?
                      There are three windings, one of them being driven (primary winding is the one that is driven), the other two are the two output windings for two power supplies. They all sharing the same core. You can also use the transformer in reverse and use other windings as the drive winding. It is just a transformer and how you want to use them and what safety requirement you need. Do not get confuse about the primary side of the circuit (dc primary circuit after the bridge rectifier that is fed by the primary AC line power source) and the primary winding of the transformer. primary winding can be driven by the the cold side of the circuit, I.E. Inverter transformer.
                      • прямо
                        Viper22A 5VSB circuit
                        by прямо
                        So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                        In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                        01-13-2024, 07:05 PM
                      • marce002
                        Macbook Core i7 2010 a1286 820 - 2850A CRAZY JUMPING voltages
                        by marce002
                        Hello
                        Need just to know how do you guys determine what the problem is, when we have some fluctuating volt, to discard a faulty TPS 51125 , or if the issue is after this IC.
                        CRAZY JUMPING
                        PP3V3_S5 = 0v to 3.33 v jumping
                        PPBUS_G3H = 12.4v to 12.48 jumping a little
                        PP5V_S5 = 2v to 5v aprox, jumping fast
                        P3V3S5_ENTRIP = crazy jumping from low volt
                        SMC_PM_G2_EN = jumping 0v to 3.3v crazy
                        STEADY
                        P3V42_G3H=3.39V steady
                        PP5V1_CHGR_VDD=5.06v steady
                        PPCHGR_DCIN= 18.29 to 18.31 jumping
                        09-08-2021, 04:08 PM
                      • kotel studios
                        FSP300-60GTF - no 5VSB, PS_ON; 5VSB carnage
                        by kotel studios
                        Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
                        Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
                        I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
                        Any ideas where to go next?
                        02-23-2025, 11:47 AM
                      • mrcliem
                        CM V700 no +5vsb, ICE2QR4765 low VCC in... Need guidance please...
                        by mrcliem
                        Hello...
                        I got my self a dead CM V700 PSU, with nothing on +5vsb
                        I have tried to fix it for the past 2 week, and I'm stuck... so i guess i post it here to get some pointer before i scrap it..
                        As you can see in photo, the psu still pretty clean, no visible damage or bulging cap.. when i got it, it still has CM seal on it
                        The +5vsb system use ICE2QR4765, I have trace and measure the voltage on ICE2QR4765 and the only voltage reading i got is in VCC 4.8v, Drain 310v and FB 3v.
                        I have read the datasheet and and still can not...
                        06-29-2023, 08:18 AM
                      • CapLeaker
                        LG 65UQ70 horizontal bars jumping
                        by CapLeaker
                        So I bought this LG 65UQ70 today at Walliworld. Put the wall mount on, set it up, worked for 30 mins and then I get these jumping horizontal bars. Let the TV do updates and let it cool down for 5 mins. Worked perfect for 2 mins. As soon the TV is warm I get the jumping vertical bars again.
                        Keep the other TCL thread in mind. Now I am questioning are all COVID 2022 / 23 TV’s bad or what? That’s two 65” TV’s one from Amazon and this one from Walmart. What are the chances on that?
                        I guess this one goes back either later today or tomorrow morning, unless...
                        08-13-2024, 09:41 AM
