LG 55LS4500-UD Vertical lines
  • braz508
    • Dec 2015
    • 8
    I got a LG 55" for free from a friend that was just going to junk it. I figured i would try to fix it, worse case i can just bring it to my local Best Buy for recycling.
    It turns of fine, also audio works but it only produces vertical lines. They are divided right in the middle of the screen. I opened it you and soon found a disk capacitor turned to ash. Do you guys think this could be cause this issue or could it be more? Should i just replace that whole board? I have worked on computer before, but not on tvs. Thanks in advance!
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: LG 55LS4500-UD Vertical lines
    Cap in PSU wouldnt cause that image--More likely tabs, panel or T-Con in that order.
    TELEFIX
    • Stanley1843
      Screen Display Vertical Multicolor Lines
      by Stanley1843
      Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
      06-29-2024, 11:54 AM
    • Falki
      Colorful LCD Vertical Lines on Samsung ue55es8090
      by Falki
      Hello there, ive recently found an older 55inch Samsung SmartTV.
      Sadly it has vertical lines at the left and one line in the middle-right.
      I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
      I have factory resetted the TV as well but also with no luck.
      I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
      A similar issue has been posted as well but also with no actual response ...
      08-12-2025, 04:19 AM
    • visionbluedemon
      Help. Sony kd-65x85dj vertical lines
      by visionbluedemon
      First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
      Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
      tried blocking LC lines too, but same results
      is it lcd panel issue or tcon board issue?...
      07-25-2025, 04:56 AM
    • gpo23
      Sony KDL-40V3000 - Vertical lines
      by gpo23
      i order a t-con because i had bad colors on my SONY KDL-40V3000 :
      With the new t-con the color are good but there are vertical lines on all the screen :
      I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
      Is there a way to fix the vertical lines on the new t-con ?
      Thank you for your help
      gpo23...
      10-04-2023, 09:11 AM
    • Firentiosi
      1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
      by Firentiosi
      Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
      The issues are as follows: the...
      11-27-2024, 12:33 AM
