Samsung HP-S5053
  • dbier63
    • Aug 2015
    • 157
    • usa
    Samsung HP-S5053
    I have a Samsung model HP-S5053 that has 2 thin vertical colored sparkling lines down the far right side. The rest of the picture and sound are fine.
    I am trying to find out if this could be a board or adjustment of some sort.
    Dan B
  • dbier63
    • Aug 2015
    • 157
    • usa
    Re: Samsung HP-S5053
    Tested with no input, colored thin lines stay in the same spot. I have a similar model which had one half of the screen dark. This was a tab that I repaired and now works. Hoping this may be the same thing.
      09-07-2024, 05:50 AM
    • Falki
      Colorful LCD Vertical Lines on Samsung ue55es8090
      by Falki
      Hello there, ive recently found an older 55inch Samsung SmartTV.
      A similar issue has been posted as well but also with no actual response ...
      08-12-2025, 04:19 AM
    • Rubenlily
      Samsung QE50Q67TAU - horizontal lines
      by Rubenlily
      First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
      I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
      I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
      I'm no expert but I've done the tape...
      08-16-2023, 01:12 PM
    • jeyoung12
      Samsung QN50Q60t lines on screen
      by jeyoung12
      Hi all
      I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
      My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
      This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
      It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
      So....i don't know what end of the C ribbon to work with...
      02-26-2024, 10:38 AM
      09-06-2024, 11:40 PM
