samsung ln46a540p2fxza red light blinking
  • cjrolke
    • Dec 2015
    • 21
    • usa
    Hello
    I have a samsung ln46a540p2fxza and the red power light is blinking, every once in a while I hear the relay on the power supply click. the screen never lights up and I can not get to a menu on the screen. I have pulled the board and looked over the capacitors, none were bulging I still went ahead and replaced some of the normal ones that go bad (the 10v rated ones)
    put everything back together and I am still having the same problem. what else can I do to troubleshoot this unit?
    I have seen a post on the internet about a bad chip would this help?
    is there any locations for a testing point to determine the issue?
    thanks
    Re: samsung ln46a540p2fxza red light blinking
    Please up load good clear pictures of the whole back side of the TV so we can see how all the boards are connected together, then the pictures of the power supply board. BN44-??????
    • cjrolke
      • Dec 2015
      • 21
      • usa
      here are picture of inside the TV let me know if you need more
        So the power supply-Inverter board combo is P/N BN44-00202A.
        Here is the diagram.
        Pictures provided by SHOPJIMMY.
        http://www.shopjimmy.com/samsung-bn4...er-supply.htm#
        The relay coil is running of the 5.1V STANDBY POWER SUPPLY.
        The black connectors on the power supply board have the labels to tell you what each pins are, you need to report the DCV reading of each pin, MAKE SURE to put the PIN NAME for each pin so we can see what are missing.
        • cjrolke
          • Dec 2015
          • 21
          • usa
          ok
          cn 1805
          1 .05
          2 2.36
          3 4.64
          4 2.37
          5 .03
          cn1806
          1 11.92
          2 0
          3 0
          4 0
          5 0
          6 10.50
          7 10.54
          • cjrolke
            • Dec 2015
            • 21
            • usa
            J 890 (big connector)
            1 4.10
            2 2.26
            3 5.16
            4 0
            5 0
            6 0
            7 13.94
            8 13.95
            9 0
            10 0
            11 0
            12 0
            13 5.15
            14 5.15
            15 5.15
            16 5.15
            17 0
            18 0
            19 13.56
            20 0
            21 13.56
            22 13.56
            23 0
            24 0
            thanks
              Please put the name of the pin after each readings.
              'The black connectors on the power supply board have the labels to tell you what each pins are, you need to report the DCV reading of each pin, MAKE SURE to put the PIN NAME for each pin so we can see what are missing.'
              • cjrolke
                • Dec 2015
                • 21
                • usa
                cn 1805
                1 .05 inverter o/off
                2 2.36 nc
                3 4.64 pwm dim
                4 2.37 gnd
                5 .03 det_5v
                cn1806
                1 11.92 12v_cold
                2 0 fb
                3 0 fb
                4 0 gnd
                5 0 gnd
                6 10.50 ld
                7 10.54 ld
                • cjrolke
                  • Dec 2015
                  • 21
                  • usa
                  1 4.10 ps-on
                  2 2.26 sync
                  3 5.16 stbs 1v
                  4 0 gnd
                  5 0 gnd
                  6 0 gnd
                  7 13.94 13.0vs
                  8 13.95 13.0vs
                  9 0 gnd
                  10 0 gnd
                  11 0 gnd
                  12 0 gnd
                  13 5.15 5.1v
                  14 5.15 5.1v
                  15 5.15 5.1v
                  16 5.15 5.1v
                  17 0 gnd
                  18 0 gnd
                  19 13.56 13.0vm
                  20 0 gnd
                  21 13.56 13.0vm
                  22 13.56 13.0vm
                  23 0 nc
                  24 0 nc
                  • cjrolke
                    • Dec 2015
                    • 21
                    • usa
                    here are close up shorts of both boards
                    thanks
                      Originally posted by cjrolke
                      cn 1805
                      2 2.36 nc
                      3 4.64 pwm dim
                      4 2.37 gnd
                      5 .03 det_5v
                      cn1806
                      1 11.92 12v_cold
                      2 0 fb
                      3 0 fb
                      4 0 gnd
                      5 0 gnd
                      6 10.50 ld
                      7 10.54 ld
                      OK, the main board is not sending the Backlights ON (>2VDC = ON, <1VDC = OFF) signal to turn on the backlights inverter circuit, but you need to verify the reading on pin which is GND pin, you show the reading of 2.37V, it should be 0V.
                      • cjrolke
                        • Dec 2015
                        • 21
                        • usa
                        I will verify when I get home
                        thanks
                        • cjrolke
                          • Dec 2015
                          • 21
                          • usa
                          I just reset ed the cables and tested
                          1. 0.03. Inverter
                          2. 2.38. NC
                          3 4.63. Pwr dim
                          4. 0 gnd
                          5 5.15. Det_5v
                            1. 0.03. Inverter
                            2. 2.38. NC
                            3 4.63. Pwr dim
                            4. 0 gnd
                            5 5.15. Det_5v
                            That one is still bad.
                            • cjrolke
                              • Dec 2015
                              • 21
                              • usa
                              So what is my next step?
                                http://www.shopjimmy.com/catalogsear...sung+ln46a540p
                                Which one of these is your main board? You may have the bad C102 SMD cap bad on the main board.
                                • cjrolke
                                  • Dec 2015
                                  • 21
                                  • usa
                                  One thing that is bizarre is I am getting an A/C voltage rating on the outside of 2 capacitors. Numbers cm808 and cm 807. They are reading an A/C voltage of 60 volts to the to of the capacitor
                                  • cjrolke
                                    • Dec 2015
                                    • 21
                                    • usa
                                    For the main board I see a part number of bn94-02077d
                                      You were using the chassis for your Black meter probe, right? Those caps are in the DC primary side so you cannot use chassis GND as the meter GND ref, you have to use the negative leg of the main filter cap as the GND REF for making any DCV reading in the primary side of the circuit. No need to worry about the primary at this point.
                                      • cjrolke
                                        • Dec 2015
                                        • 21
                                        • usa
                                        I see another part number. Bn41-00975b (2008.01.10)
                                        • matty24
                                          Samsung UE50MU6172 - red light blinking
                                          by matty24
                                          Hello. I have problem with Samsung UE50MU6172.
                                          TV won't turn on, red standby light is blinking.
                                          Power supply BN44-00807A is fine. I replaced it with the new one.​
                                          Main board BN41-02568B (BN94-12530E)
                                          I've read a dump (W25Q40CL). Can someone check it od fix it for me?...
                                          03-02-2025, 08:57 AM
                                        • Fergal22
                                          Samsung UE40F5300AK blinking red light
                                          by Fergal22
                                          I have the above tv that just shows a red light blinking twice 5 times, i have taken the back off and all the capacitors seem ok,
                                          When i disconnect the mainboard from the PSU all the led's light up blinking fast but as soon as i reconnect the mainboard back to the power supply i get the red light blinking again twice 5 times,
                                          I have attached pictures of the Mainboard, PSU and a small video (zipped) showing what happens when i disconnect the lead from the psu
                                          Any help would be appreciated...
                                          02-02-2023, 09:19 AM
                                        • norbiszoke
                                          Samsung 50AU7172, only blinking red light
                                          by norbiszoke
                                          We have this set here in our shop that is not ginving sign of life besides red light that is blinking one time after pressing the button and nothing more... After detaching the mainboard from the PSU (this set has separate board thank god?! or not...) the backlight comes on. After reattaching nothing besides red light.... Can anyone from the forum help me here? Thank you in advance. Here's a link with images of the mainboard and the memory IC's that are on it.
                                          Regards, Norbert!...
                                          04-17-2024, 06:54 AM
                                          09-07-2024, 05:50 AM
                                        • 3DDD
                                          Samsung UE46D6100 LED TV blinking red light indicator
                                          by 3DDD
                                          Hello, I have a Samsung UE46D6100. It cannot be turned on, only the red status LED flashes, the power supply part bn44-00458a gives an output of 5V(A), it is probably functional. I don't know where to look for the error, according to the video it should be a faulty mosfet. I found a mosfet marked WAAH, I don't know what it is. Can anyone help me?...
                                          02-20-2025, 12:51 PM
