Samsung LE-40R88BD turning off and on
  • grendal10
    • Apr 2015
    • 25
    • United Kingdom
    hi
    wondered if anyone can help I have a Samsung LE-40R88BD which turns on and off, ive changed nearly all the capacitors on the power board and replaced the eeprom chip but no change, the screen doesnt fade as normal,
    the image almost distorts before going black hope fully the pictures might help, ive fixed a few samsung tvs with bad capacitors which is why i was confused with the eeprom replacment not fixing the problem any ideas would be much appreciated
  • Hamie
    • Apr 2014
    • 1383
    Re: Samsung LE-40R88BD turning off and on
    Jump 5vstby with PS-ON
    And also jump 5vstby with BL-ON
    Backlights should now come on and stay on.
    Check all voltages are accurate to the main board.
    • sordids999
      • May 2013
      • 2161
      You could try warming up this area with a hair dryer it may be worth a shot had the same problem with turning on and off
      • grendal10
        • Apr 2015
        • 25
        • United Kingdom
        Thanks ill give them a try and see what happens
        • grendal10
          • Apr 2015
          • 25
          • United Kingdom
          could anyone tell me what pin 1 power on/off is ment to be as its currently 1.9v
          • vinceroger69
            • Mar 2012
            • 6714
            whats the power supply number?
            • grendal10
              • Apr 2015
              • 25
              • United Kingdom
              power supply model is: ip-231135a
              • tech2014
                • Aug 2014
                • 807
                Could be a poor solder joint. I have fixed a couple of TV where power would come on and off by itself. I resoldered everything on the power supply heat sinks and it fixed the problem. Its worth a try.
                • grendal10
                  • Apr 2015
                  • 25
                  • United Kingdom
                  i might have sorted it, its stayed on for the last 20mins, ive turned d-watchdog and watchdog off in the service menu. so far so good!
                    09-07-2024, 05:50 AM
                  • Jacksoft
                    Samsung 225MW EEPROM bootloop
                    by Jacksoft
                    I got an old Samsung 225MW TV with BN41-00825 motherboard.
                    Since the TV has a buzzer when it starts it makes a beep. The main problem is that the TV goes in a sort of bootloop and beeps every 2-3 seconds.
                    So I attached the VGA UART cable and read the debug data using a RT809H programmer:
                    According to the Service Manual all the voltages looks good, so I made a backup of the internal flash and all the EEPROMs (1 Settings + 3 EDID) and cleaned the EEPROM.
                    Now the TV boots but it's stuck on VGA. If I try to change the source it goes to TV, restarts...
                    02-14-2025, 04:18 PM
                    09-06-2024, 11:40 PM
                    09-06-2024, 08:40 PM
