samsung PN60E550D1FXZA sound no picture
  • matt@bdtinc.com
    • Jun 2015
    • 19
    I have a Samsung PN60E550D1FXZA with sound and no picture. When plugged in i briefly get correct Vs and Va which then drops down to 0. With only X-main hooked up, it drops slowly. With both X and Y hooked up it drops significantly faster (they are in series). I have checked both Y buffers and found no shorts. I read in another thread here that freezing U5014 and the caps around it can cause it to turn on temporarily and let you confirm the fault but I haven't had any success with that (using an upside down air can, i'm going to pick up proper freeze spray this weekend).
    I am just curious if the almost immediate dropping of Vs and Va when Y-main is connected is a confirmation of a fault/short in the Y-main or just a by-product of being hooked up to the buffers and screen?
    Is there any other way to isolate whether the X-main or Y-main is indeed the culprit?
    Thanks!
  • jjanssen7
    • Nov 2012
    • 252
    Re: samsung PN60E550D1FXZA sound no picture
    There are several threads that apply to this TV. Should be helpful info here:
    https://www.badcaps.net/forum/showthread.php?t=43075
    https://www.badcaps.net/forum/showthread.php?t=49827
    • TR103
      by TR103
      - it keeps rebooting
      01-22-2025, 04:12 PM
    • Mgiffune
      by Mgiffune
      06-09-2024, 10:28 AM
    • Ierwin
      by Ierwin
      05-13-2025, 03:31 PM
    • jchang
      Samsung UN70NU6900F no picture and no sound
      by jchang
      Hi all
      I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
      Symptom:
      No picture no sound.
      When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
      No sound at all.
      What I tried:
      1. I tried unplugging the left or right ribbon...
      01-09-2023, 06:28 PM
    • Dodgethis
      Samsung QN75Q6DRA, No Picture, Has BL, and Sound
      by Dodgethis
      Hello all,
      This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
      09-11-2024, 07:39 AM
