Panasonic TC-P65S2 Red Light 7 Blinks
  • colormebad
    colormebad
    • Dec 2010
    • 114
    Have a Panasonic TC-P65S2 that was playing and just went off... The red light on the front keeps blinking 7 times/ Pause, then starts over... You can turn it on and hear a relay/relay's click, then a few sec's another click... Then you have to unplug it and plug the ac back up, and it does the same thing all over again... I pulled both boards and soldered every connection on there , but still the same thing... No swollen caps, and checked all diodes and none shorted.. Had 5 diodes that showed shorted , but after unsoldering one end they were fine.... Any other thing I can check, or a common probkel with this model ??? Thanks
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P65S2 Red Light 7 Blinks
    your info is a bit vague.
    What boards? "I pulled both boards and soldered every connection on there ,"
    Where? " Had 5 diodes that showed shorted"
    7 blink code traditionally is one or all of these. SC,SD,SU boards.
    Step 1: search the model in the forum, if it has problems someone has bound to reported it. read them all because what can cause 7 blink can also cuse others like 10 blink etc.
    search for a service manual.
    search Shopjimmy check out the SC board and that gives 3 models which use it, search them, search the board number.
    TNPA5175 is pretty much a TNPA5081 board on steroids and you could apply fault finding for 7 blink from any 2010 FHD model be it a S2 series or the G20/25 series, size does not matter.
    Bad SC board would be high on the list but could be more.
    here's a story https://www.badcaps.net/forum/showth...C-P65S2&page=2
    7 blink, replaced Sc , blew that and mentions lines and needing SU.
    So, disconnect the Sd,Su from the Sc. remove the 4 grounding bolt on same boards(Sd,SU).
    Locate 2 pin connector Sc50, short those pins. turn TV on. If it still 7blinks Sc is bad.
    Now you wil need to check the SD,SU for short.
    If you read this post that should get you going on that
    • colormebad
      colormebad
      • Dec 2010
      • 114
      I soldered all boards! I detached the Sc board and now have 6 flashes, which goes back to the Sc board.... I pulled the Sc board and found 14 transistor's 1 diode shorted so far..... I have made some bids on ebay for a Sc board... I talked to another tech on another forum earlier, and he said they do make a repair kit, but said most don't send you enough parts...
      • tw2005
        • Oct 2011
        • 6458
        detaching the Sc and getting 6 does not prove anything really as this is what the TV would do anyway but sounds like the Sc is shot.
        Just make sure you do those sd/su checks too.
        Agreed buying a kit is risky, keep the old board though, you may want to get it rebuilt and I've seen dead board being sold now as cores for repair and getting reasonable money because in a lot of cases rebuilding is the only way to get one going again. very expensive and hard to get SC boards for lots of models now.
        • colormebad
          colormebad
          • Dec 2010
          • 114
          Where is a good place that rebuilds boards ??? I have no problem replacing shorted or bad parts, but looks like the Sc board has more than the normal parts shot.... I went back today and found 17 shorted transistor's , 1 shorted diode... But I think I will look for a good board... Nut I will try the other checks also first....thanks
          • tw2005
            • Oct 2011
            • 6458
            Where is a good place that rebuilds boards ??? I have no problem replacing shorted or bad parts, but looks like the Sc board has more than the normal parts shot.... I went back today and found 17 shorted transistor's shorted , 1 shorted diode... But I think I will look for a good board... Nut I will try the other checks also first....thanks
            No idea now, but could try Quad City TV. they do the TNPA5081 boards so should be able to work this one out but at $120 I'd expect this may hit $150 or more to repair
            or ask if this person can
            http://www.ebay.com/itm/REPAIR-SERVI...YAAOSwrklVUiNa
            http://www.ebay.com/itm/TNPA5175-TC-...4AAOSwHQ9WYg3Y
            http://www.ebay.com/itm/PANASONIC-TC...cAAOSwI-BWN9ff
            • colormebad
              colormebad
              • Dec 2010
              • 114
              I bought the repair kit and have all the shorted parts out of the board...... Does anyone have a schematic showing a parts list and what they are ??? I have a resistor on this Sc board R551 that had a small place on it but not sure its bad.... Its not open and reads in the meg's ....
              • tw2005
                • Oct 2011
                • 6458
                10 ohms, should have marking 100, if you can't read that then good chance it's burnt.
                If that's shot I guess Q453,454,551, IC521 are all being replaced? How's the 5.6 ohm gate resistors?
                Mind listing out the entire parts listed / supplied in the kit? or a hi res shot so i can have a good look. Any instructions with it or just parts?
                I'm particularly interested in what SMD parts they've supplied
                • colormebad
                  colormebad
                  • Dec 2010
                  • 114
                  Here is the Repair kit they are sending me.... I have already pulled the 14 transistors....
                  http://www.ebay.com/itm/Panasonic-TX...torefresh=true
                  Integrated Circuits 4 Included with Kit
                  Transistors 19 Included with Kit
                  Diodes 1 Included with Kit
                  It better show the layout of the transistors' because the 14 that is shorted are different part #'s
                  • tw2005
                    • Oct 2011
                    • 6458
                    yeah ok, so it's on its way. Unfortunately I'm relocating so I'm virtually out of time. I don't know this board but it's similar design to the 5081 SC.
                    What I'm concerend about is what might not be included that could be faulty on your board. Which is why I'd like to see the the parts.
                    If the image is accurate then at a guess there are some bits otentially missed.
                    If Q661 is shorted, then check Q701,Q702 for shorts, check IC773 short between pin 3 & 5. IC771 is also important as it supplies the 5V to ic773 but you won't know which is bad if there's a short until you isolate one.
                    I see they have an IPD MIPxxx by the looks of it. Have not replaced one of those yet but have read of someone on a board doing so.
                    • colormebad
                      colormebad
                      • Dec 2010
                      • 114
                      I knew all the resistors that had 100 on them all read 10 ohm's like you said' except R551...It read 8 meg after I took it out... I went across the top of the resistor with a small screwdriver where it look like a small burnt hole, then rechecked it and it read open....
                      Here are the list of the 14 transistors I found shorted, that looks like the ones in the kit, if they have some info showing these are the ones....
                      Q402
                      Q403
                      Q404
                      Q405
                      Q406
                      Q421
                      Q422
                      Q423
                      Q424
                      Q425
                      Q452
                      Q453
                      Q454
                      Q661
                      D652 Was shorted which looks like its in the kit...
                      That resistor is not in the kit and I hope there is not parts missing like you said...
                      Will check for the shorts mentioned above.... thanks
                      • colormebad
                        colormebad
                        • Dec 2010
                        • 114
                        Just checked Q701 and Q702 and they are not shorted...
                        Also' no short between pin 3 & 5 of IC773
                        • tw2005
                          • Oct 2011
                          • 6458
                          sounds promising. don't forget to check the buffer boards.
                          • colormebad
                            colormebad
                            • Dec 2010
                            • 114
                            What was the testing you do on the buffer boards ??
                            • tw2005
                              • Oct 2011
                              • 6458
                              these are my own figures which is good enough to judge, just do Vfo, 5v-f, Vscn_f each with respect to the vfg which are those metal tabs, sc disconnected and disconnect the small su/su ribbon. if the results are weird try reversing the probes but so long as there is no short or low ohms they will be ok. vfo typically will be shorted on a bad board
                              • colormebad
                                colormebad
                                • Dec 2010
                                • 114
                                Thanks A lot!
                                • colormebad
                                  colormebad
                                  • Dec 2010
                                  • 114
                                  Thanks A lot!
                                  SD42
                                  Pin1 2.1M
                                  Pin2 220K
                                  Pin3 No Reading
                                  Pin4 No Reading
                                  Pin5 6M
                                  Pin6 6M
                                  Pin7 No Reading
                                  Pin8 6M
                                  Pin9 No Reading
                                  SU41
                                  Pin1 No Reading
                                  Pin2 2.2M
                                  Pin3 No Reading
                                  Pin4 220K
                                  Pin5 No Reading
                                  Pin6 No Reading
                                  Pin7 No Reading
                                  Pin8 7.2M
                                  Pin9 No Reading
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    SD42
                                    Pin1 2.1M
                                    Pin2 220K
                                    Pin3 No Reading
                                    Pin4 No Reading
                                    Pin5 6M
                                    Pin6 6M
                                    Pin7 No Reading
                                    Pin8 6M
                                    Pin9 No Reading
                                    SU41
                                    Pin1 No Reading
                                    Pin2 2.2M
                                    Pin3 No Reading
                                    Pin4 220K
                                    Pin5 No Reading
                                    Pin6 No Reading
                                    Pin7 No Reading
                                    Pin8 7.2M
                                    Pin9 No Reading
                                    perfect, what sort of meter you have? I have so much trouble getting readings from other posters that are reliable using cheap meters.
                                    I'm sitting at a bare table, on my laptop surrounded by boxes and packers.
                                    Moving from
                                    Darwin
                                    to Brisbane
                                    • colormebad
                                      colormebad
                                      • Dec 2010
                                      • 114
                                      Moving from
                                      Darwin
                                      to Brisbane
                                      I'm using an old Fluke I used years ago when I worked for a few Tv / Satellite/ Etc repair shops....
                                      • colormebad
                                        colormebad
                                        • Dec 2010
                                        • 114
                                        Looks Nice where your moving... And where you moved from
                                        • Alicat
                                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                          by Alicat
                                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                          Model number is TH-50PZ85U
                                          Power comes on and the red power light stays on solid.
                                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                          I also hear a few clicks.
                                          I also think my parents said there was a thunderstorm and the TV failed after that.
                                          Section 6 in the service manual talks about power and no screen,...
                                          10-30-2024, 10:09 AM
                                        • cloo
                                          Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                          by cloo
                                          I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                          It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                          So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                          After doing a factory reset this problem was gone and the picture was back to...
                                          01-06-2025, 06:02 AM
                                        • Elecfronicsssss
                                          DA0NJJMBAG0 charging light blinks
                                          by Elecfronicsssss
                                          Laptop motherboard DA0NJJMBAG0
                                          PROBLEM-WHEN I PLUG THE CHARGER WITHOUT BATTERY THE CHARGING LIGHT BLINKS AND WHEN I PRESS POWER BUTTON THE CHARGING LIGHT STOPS BLINKING AND STAYS ON BUT THE POWER LIGHT DOESNT TURN ON AND LAPTOP ALSO DOESNT TURN ON NO FAN SPINS NO KEYBOARD LIGHT.
                                          CHECKED- ON S5 STATE TGE LAPTOP HAS 5V ON USB 3.3V BUT I DIDNT GET 1.8VOLTS ON BIOS PIN NO 8 WHILE PLUGGED IN AND EVEN ON S5 STATE.
                                          GUIDE ME WITH THE PROBLEM..
                                          SUMMARY-
                                          1.NO 1.8VOLTS ON BIOS PIN NO 8.
                                          2.S5 STATE ((PRESSING POWER BUTTON)))VOLTAGES ARE PRESENT...
                                          05-12-2025, 02:32 AM
                                        • Vebririon
                                          panasonic TX-P50V10E 6 blink led problem
                                          by Vebririon
                                          I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
                                          Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
                                          I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
                                          05-17-2025, 10:16 AM
                                        • icareservicezone
                                          Synology DS918+ blue light blink
                                          by icareservicezone
                                          Synology DS918+
                                          Model name : GDI41L2
                                          p/N: 08-06GDI4116
                                          Version: V1.6
                                          Problem : blue light blink...
                                          05-24-2025, 11:53 PM
