LG 60pv250 no picture with sound
  • mirancer
    • Nov 2015
    • 8
    I have a LG 60pv250 tv with no picture but has audio. I have searched the other posts regarding the same tv and followed the basic troubleshooting steps posted for the same model tv, but the answers tend to go in a different direction. I have looked for cracked solder joints, bad fuses, bulging capacitors, reseated the connectors, the voltages that are on the labels seem to be in spec but still not getting a picture or any further on finding out which board could be bad. Could someone lend me a hand in getting some kind of definitive answer? I would like to get this tv back up and running for my friends kids. They would really appreciate it.
  • Hamie
    • Apr 2014
    • 1383
    Re: LG 60pv250 no picture with sound
    Have you tried test patterns?
    If not upload a picture of the control board.
    • mirancer
      • Nov 2015
      • 8
      Hi Hamie,
      I was hoping to get a response from you. From reading the other posts regarding this particular model, you know what you're talking about. I have tried the test pattern using this post https://www.badcaps.net/forum/showthread.php?t=50371 with no results. Screen remains dark and no pattern.
      • Hamie
        • Apr 2014
        • 1383
        So I noticed you are saying all voltages are in spec.
        Just to clarify you have checked ALL the critical voltages.
        VS VA VSC -VY Z-BIAS
        They must all match the sticker.
        • mirancer
          • Nov 2015
          • 8
          Here's the label the test points and the voltages i measured.
          Vs TP
          Vs Voltage
          Va TP
          Va Voltage
          VSC TP
          VSC Voltage
          VY TP
          VY Voltage
          VZB TP
          VZB Voltage
          Somehow in my initial voltage testing I either forgot the VZB voltage reading, didn't measure it, or couldn't find it. Those voltage readings are with the tv plugged in and turned on. Well at least I think it was. The VZB voltage is lower then what it says on the label.
          • Hamie
            • Apr 2014
            • 1383
            http://m.ebay.co.uk/itm/191568197879?_mwBanner=1
            • Hamie
              • Apr 2014
              • 1383
              Most of the parts in that kit will be surface mount.
              How's your soldering skills?
              • mirancer
                • Nov 2015
                • 8
                Soldering skills are excellent. I can solder 0402 smt resistors. Thanks for your help with this. I will purchase the kit and update you you on the outcome.
                • mirancer
                  • Nov 2015
                  • 8
                  Hamie,
                  I have received and replaced all the parts in the kit that you suggested that I buy. I am still reading a low VZB voltage. When I initially plugged it in, I looked at the display for any type of glow or OSD. I saw nothing. Then i probed VZB and got a reading of 70 volts and dropping. Turning off the tv and turning it on again i rechecked all the other voltages. Everything was in spec still. Remeasured VZB and noticed the voltage was down to 30 volts. Turning the tv off and on while measuring VZB, voltage would go up about 3-5 volts then start dropping back down. What would be the next step? Thanks
                  • mirancer
                    • Nov 2015
                    • 8
                    Bumping message.
                    • mirancer
                      • Nov 2015
                      • 8
                      One last bump for this post. I've replaced what I was told to and still nothing. Someone? Anyone?
                      • jwarnes
                        • Feb 2014
                        • 29
                        I feel your pain. Mine is doing the same.
                        • TR103
                          by TR103
                          - it keeps rebooting
                          01-22-2025, 04:12 PM
                        • Mgiffune
                          by Mgiffune
                          06-09-2024, 10:28 AM
                        • Ierwin
                          by Ierwin
                          05-13-2025, 03:31 PM
                        • jchang
                          Samsung UN70NU6900F no picture and no sound
                          by jchang
                          Hi all
                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                          Symptom:
                          No picture no sound.
                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                          No sound at all.
                          What I tried:
                          1. I tried unplugging the left or right ribbon...
                          01-09-2023, 06:28 PM
                        • ChaosLegionnaire
                          by ChaosLegionnaire
                          09-13-2022, 09:02 AM
