Hi Guys i have a 48'' edge lit LED tv that produces a full lit screen then half a portion of screen then shortly after nothing. Does anybody know where i can get hold of a replacement I've checked Ebay for smashed screens but none are available
Toshiba 48'' edge lit backlight problem
Tags: None
Re: Toshiba 48'' edge lit backlight problem
I've tried with great difficulty. I've watched the videos but i can't even get the led off without having to scrape them offComment
Cheers Gary I dont have a video yet but can link one, watch this
https://m.youtube.com/watch?v=hh3z_dkkcUMPlease Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
https://www.facebook.com/Telford-Tel...7894576335359/Comment
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by DobrowolHi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?04-28-2025, 04:30 PM
by ononoshello everyone!
As the title states i am an owner of an LG flatron M2362DP 23 inch monitor Tv. Since i currently use it as a tv i'm posting the problem on the "troubleshooting tvs and video sources" section.
I'm from Greece so English isn't my native language, so please forgive me for any mistakes i make. I have basic knowledge in electronics, and although i have a degree, many things have changed since i finished a 2 year coarse (over 30 years ago). Occasionally i repair easy stuff, mostly things that break at home like appliances.
So i decided to try to... -
by fanaticgameshello I have a backlight problem on this TV, if I unplug the cn201 cable the backlight works perfectly and the voltages are 13v if I connect the cn201 cable the backlight goes off and the voltage drops to 12v, I assume it's a motherboard problem, the question is has anyone had a similar problem? I want to understand if the motherboard is repairable or it's not worth wasting time...
Hello Guys,
I received Toshiba Qosmio X755 that has a charging problem and I'm stuck trying to figure out the problem.
- When battery is unplugged i works without any problem.
- When I plug in the battery after plugging in the charger, it works correctly and the battery is charging.
- When I plug in the charger after inserting the battery, it stops working. ( voltage dropped and consumed 8A, reaching the maximum capacity of my bench power supply for 5 seconds, and stop working after )
Can you help me diagnose the problem? I have attached... - Loading...
