LG 50PM4700 No Power Up SOLVED
  • mmartell
    • Oct 2013
    • 3189
    2012 50 inch 720p 3D Smart tv had standby but would not power up. Before I could get my hands dirty I looked up the model number on Shopjimmy and found a repair kit for the power supply consisting of several ic's, several transistors and diodes, a cap and a couple of fuses.
    When I ran over the board with my meter I didn't find anything amiss and no blown fuses. The cap however, a 22nf 1.25kv film cap (C802) was reading way too low. Replaced that temporarily with an 18nf 630v cap for testing purposes and the tv came to life. A replacement cap of 1.6kv is on its way.
    Now being the curious type I wanted to see what the pic was like so I went to plug a coax into the antenna port but couldn't find it. Seems the PO/joker/bozo managed to shear the connector right off the tuner module! I could replace the entire board (not!) or even the module but I think this one cries out for a "workaround". Will post pics when I get to it.
    Btw I just repaired a Samsung lcd last week with failed film cap at CI802 and the location on the LG was C802.Spooky, lol.
    Last edited by mmartell; 11-13-2015, 05:55 AM. Reason: typing on a damn cell phone...
  • mmartell
    • Oct 2013
    • 3189
    Re: LG 50PM4700 No Power Up SOLVED
    disregard...
    • mmartell
      • Oct 2013
      • 3189
      I harvested a small section of conductor from a piece of coax cable and soldered in the hole to where it seemed the original was. After verifying the location was correct I slid a coupler over it and soldered the threads to the shield and all is well. Except that the coupler sticks out quite a bit more from the back of the set than should reasonably be expected. May go back in or simply issue a caveat to the next owner to BE CAREFUL.
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
        by sam_sam_sam
        03-31-2024, 02:12 PM
        09-06-2024, 05:59 AM
