Lg 60pz550
  • krygods
    • 257
    Lg 60pz550
    When I got this TV it would turn on and shut itself right off.
    Diagnosed it down to being a bad ZSUS by following Toms guide.
    I repaired the ZSUS with the repair kit from ShopJimmy.
    TV powered up and worked great for about 30-45 minutes, when I looked at the TV again I had a picture looking like this.
    Anyone know what the cause of this would be?
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Lg 60pz550
    That looks like your Z sustain board failed. Are you sure you did a good soldering job on all replaced components? Check the fuses on the Z board see if any of them opened
    • krygods
      • 257
      Re: Lg 60pz550
      yea i'm positive i did a proper job on the soldering
      im opening the tv back up right now, let you know what i find
      • krygods
        • 257
        Re: Lg 60pz550
        Fuse on the Z sustain board is fine
        Any suggestions to narrow down the cause?
          Re: Lg 60pz550
          Check Vzb voltage. Definitely a Z-sustain issue.
          • krygods
            • 257
            Re: Lg 60pz550
            VZB is showing 41.92VDC
            • freakaftr8
              • Oct 2012
              • 3743
              Re: Lg 60pz550
              Check soldering on all coils on that board. Even if they look good try to resolder them make sure that they're making a good connection. There's a possibility you might be seeing the reason the board blew in the first place happening all over again
                Re: Lg 60pz550
                Much too low -- needs to be around 90-120V for an LG 2011 panel.
                • krygods
                  • 257
                  Re: Lg 60pz550
                  So even after I check all these I'm assuming that I'm going to need a new repair kit for the Z sustain board?
                  If this is the case is there any testing that can be done after the new repair kit is installed to avoid this same problem of the Z sustain blowing again?
                  • krygods
                    • 257
                    Re: Lg 60pz550
                    Inductor coil solder joints look good no cracking nice and shiny.
                    All but one coil did have 'ring around the collar' cracks but I touched them all up while installing the repair kit from SJ
                      Re: Lg 60pz550
                      Have you tried adjusting the Vzb point?
                      • krygods
                        • 257
                        Re: Lg 60pz550
                        No I will do that right now.
                        • krygods
                          • 257
                          Re: Lg 60pz550
                          VZB adjustment causes no change in the voltage.
                          Also noticed if the probes are left on the VZB test points the voltage starts to steadily drop.
                          Also noticed that VZB DCV is never the same, sometimes starts around 80 DCV sometimes 60DCV and I've even seen it as low as 46DCV before the voltage starts slowing dropping off.
                          • krygods
                            • 257
                            Re: Lg 60pz550
                            I found a Z Sus board on ebay that will arrive today.
                            Question: Is there any risk in just putting the Z Sus into the TV and testing to see if it works, or is it possible for something else with a problem in the TV to burn up the Z Sus?
                            • SdlewisSr
                              LG 60PZ550-UA with color gradient problems
                              by SdlewisSr
                              I have an LG 60PZ550-UA plasma TV that has problems correctly displaying certain (not all) color gradients. It is most noticeable in certain shades of blue, brown, and skin tones. I also have an LG 50PT350-UD plasma TV that has nothing wrong with it that I am comparing with. I am including five sets of images. I fed both TV via HDMI with the same videos/movies and took pictures of the same area of each screen. I labeled them "Good Example # (LG 50PT350-UD)" and "Bad Example # (LG 60PZ550-UA)". Each set is numbered from 2 to 6 where the "#" is in the filename.
                              07-10-2022, 07:21 PM
                            • alfredomfr1
                              TV Plasma LG 60PN5000 ZSUS 15v missing
                              by alfredomfr1
                              All Voltages are OK except ZSUS 15v.
                              YSUS board disconnected still 15v missing.
                              ZSUS was replaced: 15v missing.
                              Any help will be appreciated...
                              04-29-2022, 11:26 AM
                            • reessi
                              LG Plasma ZSUS Flashing Screen, No Booting! - 50PB690V
                              by reessi
                              Replaced Zsus beginning of year as most transistors were short stopping tv powering up.
                              Now screen flashes on off continually and ZSUS ticks. Looking like replacement maybe faulty or could something else cause it to shut down.
                              If I remove both tabs from ZSUS to screen but keep all other connectors to ZSUS on then TV boots properly but screen very dark without ZSUS output, no ticking from ZSUS. So it only shuts down when under load from screen.
                              If it is ZSUS then how to fault find, I already looked for shorts. No transistors shorted or caps and its...
                              12-13-2017, 01:18 PM
                            • x2006nzl
                              Lg 60PZ550 no picture
                              by x2006nzl
                              Hello I acquired a lg 60PZ550 no picture, but the backlight powers on , just no image, I read this can be the mainboard?
                              05-28-2022, 07:27 AM
                            • Salvatore057
                              plasma TV Lg 42w451 - why is the zsus igbts damaged when the ysus is plugged?
                              by Salvatore057
                              I am trying to fix my plasma TV which is not powering on due to damaged IGBTs. I have changed two igbts and 2 IC drivers on the zsus and also two igbts on the ysus.
                              Now everytime I plugged the ZSUS and the YSUS boards to the power board, the two 30f124 IGBT on the ZSUS are damaged and the TV stays in standby mode. When I plug the ZSUS board alone the TV turns ON but I do not see pictures. When I plug the ZSUS board without the two 30f124 IGBTs and the YSUS board, the TV powers on with a picture.
                              I am lost, should I change the YSUS board? Is the YSUS board damaging...
                              04-29-2018, 01:29 PM
