Re: Sharp AQUOS 70" LCD model LC-70LE550U
That's correct the right side of the screen is going to be full white because it has no voltage or any data being fed to it because that cable is disconnected. What you need to do is connect that cable so you have both cables connected to the Tcon board. Then disconnect the small flat cable that I showed in my previous picture. Once you do that see if you have a picture spanning all the way across the screen its going to be a little darker on the right side but you'll still see something. Do you have that or not?
.....You may have a powering issue such that a "weak component" is not able to drive the panel sufficiently so the system is shutting it down BUT it is more likely that you aren't seeing a "perfect picture" and that is a "hint" that there is a "panel issue" and NOT a powering issue.....
I also need to clarify something I said earlier about when the left side ribbon cable is disconnected from the T-CON(1 of 2) to panel the left side is as described and has a good picture but the right side has backlighting with what appears to be full brightness, not black or dark as I previously described. Here is an image with the left cable disconnected.
Further, leave the cables at the tcon connected. At each side in the lower corners, there are smaller cables (very similar to the tcon cables that are "unclippable"). Try unplugging one of those, do you get a full picture?... Try the other corner side, do you get a full picture? You should.
Exactly what he said. This is completely reversible all you're doing is unplugging a cable on the side to see if the side driver is causing the problem or notLeave a comment:
I think you need to look at your "perfect picture" a bit closer... :-) If you can, feed you tv a signal from a test pattern (can be found on various dvd's, etc). Then do your your cable "pulls" and look carefully at the resulting picture with a given test pattern... looking for lines (vertical or horizontal), color "shifts", missing portions. You may have a powering issue such that a "weak component" is not able to drive the panel sufficiently so the system is shutting it down BUT it is more likely that you aren't seeing a "perfect picture" and that is a "hint" that there is a "panel issue" and NOT a powering issue.
Further, leave the cables at the tcon connected. At each side in the lower corners, there are smaller cables (very similar to the tcon cables that are "unclippable"). Try unplugging one of those, do you get a full picture?... Try the other corner side, do you get a full picture? You should.Last edited by budwich; 11-11-2015, 07:01 AM.Leave a comment:
to be honest with you your power supplies working fine as you wouldn't have half the screen if it were bad. Your main boards working fine because its supplying the signal to the tcon board or you wouldn't see anything on either side of the screen. So you're left with a panel problem. You can however disconnect that small flat ribbon cable off the bottom side of the panel connecting to the side driver on the non functioning side. The non-functioning side will be darker but you should get an image on that side with both of your ribbon cables connected from the t-con to the panel just leaving the small flat ribbon out of the equation.
Here is a picture of what you should disconnect to test off the right hand side of the panel facing the front.Leave a comment:
Here is a picture of what you should disconnect to test off the right hand side of the panel facing the front.Last edited by freakaftr8; 11-11-2015, 02:22 AM.Leave a comment:
Yes don't concern yourself with the flat green board that are attached to the bottom of the panel where the two flat white ribbon cables go from the tcon. I'm more concerned about the board that I'd attached to the side of the panel on the side you are having the problem withLeave a comment:
Note Vizio uses the sharp panel
https://www.badcaps.net/forum/showthread.php?t=49281Leave a comment:
I just took a look at it and the panel is surrounded by 4 thin green boards that have several cables attached per board from the front of the panel. Are these the boards you are referring to?Leave a comment:
Have a read. Don't pull anything off the screen but just read this topic and you will see where these ribbon cables lie and you will probably get the gist of what could be going onLeave a comment:
I don't have access to it at night. It is to big to work on inside my home so I have placed it inside a 10x12 shed in my backyard. I will see if those boards exist in the morning. Do I need to remove any more parts to see them or should they be easily seen?Leave a comment:
Do you have small thin boards that attach to the side of the panel? With the back off looking at the side of the screen do you see a small flat white ribbon cable connecting to the bottom side of each side of the panel? These boards run the length of the panel on each side there covered up by a black metal frame that surrounds the panel on each side they are underneath that frame you will be able to see the flat white ribbon cable exposed at each bottom side of the screen on the sideLast edited by freakaftr8; 11-10-2015, 11:37 PM.Leave a comment:
When the ribbon cable on the left side(viewing from back) is removed the backlight comes on and it has a good picture on the left(as viewed from the front side). The right side as viewed from the front only has the backlights and dark or black image. I don't know about other Sharps but this menu begins on the left side. I hope it is familiar enough to figure out. thanks for looking
These are the 4 cables I am referring to.
Okay so I'm confused when you disconnect the right hand side ribbon cable you have a perfect left hand side of the screen? Or when you disconnect the left hand ribbon cable you have a perfect right side of the screen?
You say that when you disconnect the left-hand ribbon cable are you speaking about behind the TV looking at it from behind the left and so you have a perfect right hand side of the screen working because on sharp TVs the menu is located on the right side. Is at the side of the screen that is still working the left hand of the screen will probably either be white or black
For some reason this is sounding all too familiar...Last edited by freakaftr8; 11-10-2015, 11:04 PM.Leave a comment:
Symptoms: No display, no backlight, front display light blinks off once every 15 seconds
other: Unit powers on indicated by light under "Sharp" name
I purchased this TV hoping to repair it. My troubleshooting skills might seem a little primitive.....actually they are primitive but I am trying. This is what I have noticed. The remote power button and the side panel on/off switch do not toggle the power without disconnecting the cables mentioned below. If I disconnect the left side ribbon cable between the T-CON board and the panel the left half of the display and the backlights will come on and display a half perfect menu. Disconnecting the left side cable also allows the power to be cycled with either the remote control or the side panel on\off switch. When the right side T-CON ribbon cable(T-CON to panel) is removed the backlights and image remain off. Disconnecting the 4-wire cable(12v PS to T-CON)or the ribbon cable(Main board to T-CON board) also allows the backlights to come on. I am assuming since my panel is capable of displaying half an image it should be capable of displaying a complete image. I am also guessing the T-CON board has failed but would like some advice from someone familiar with Sharp LCD TV's.
I would also be eternally grateful to anyone who has a service manual for this model TV.
Thank you very muchTags: None
by scubacamperI found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display... -
by RozpHello Everyone,
This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area.... -
by klassicHi community,
I will describe my problem with a TV in those short following terms to be the most precise :
What i have :
Sharp Aquos LC-60LE635E
power board DPS-162KP-1
main logic board QPWBXF733WJN2
symptoms :
white led light logo at startup,
after 2 minutes, blinking 3 times a row, repeating
no backlight (and apparently no picture, checked panel with flashlight)
no startup sound
powerboard investigations :
1-2 PNL : 0v
3-4 GND
5-6-7-8 UR : 13.15v
9-10-11-12... -
by SmartSarahDear,
I can not pinpoint the following problem on my Sharp TV LC70LE747E.
While the left side of the screen is not affected at all the right side of the screen gradually fades to a kind of dark. I can best describe this darkness like a totally worn out CRT display or a gamma correction totally out of range. This darkness flickers like a flame, a dark one tough.
Sometimes when I restart the TV it disappears for a while.
The problem worsened over time the last few months.
I've replaced the t-con module without success. The problem remains.
by foxyUKCan anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12.... - Loading...
