LG 50PC55 Plasma–multiple attempts to turn on; but now no image... help
  • freakaftr8
    • Oct 2012
    • 3743
    Re: LG 50PC55 Plasma–multiple attempts to turn on; but now no image... help
    If I'm not mistaken this TVs Vizio variant has capacitor problems on the power supply that prevents it from starting up properly. If I remember there's like 5 or 6 of them that need replacing. It's been a few years that I had one come into me but this is why I remember
    • mojo7676
      Mojo7676
      • Nov 2015
      • 19
      • uk
      update - sorry for the delay...
      so heated the board as shown in the pictures and when i got to the two black rectangular blocks (white block above it, and a blue one above the white one), the tv turned on.
      Now, i'm assuming it's one or both of these blocks which are a bit dud. Of course, it could also be the case that the heat diffused and heated up another otherwise dud part... I didn't have the presence of mind to check out the black capacitors on the left hand side of the board but might do that tomorrow just in case. So anyway, given that i'm still not sure, the question is, is it possible to source replacement bits on their own and if so, where from? Also, I've no idea how to identify/name them in order to buy them and then, on top of that, am not sure how much of a complex/detailed job it is in terms of removing and replacing offending components. I have soldered in the past but anything more complex than that might be challenging.
      The alternative is to switch out the whole board but that might have the same fault. There are various part numbers on the board including EAX32412301 EAY32957901. I've seen a couple of ebay uk -
      http://www.ebay.co.uk/itm/POWER-BOAR...EAAOSwQPlV9HqU
      and
      http://www.ebay.co.uk/itm/LG-EAX3241...IAAOSwAYtWOL~j
      so that's where i'm at right now.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Ignore this post.
        • jose6326
          • May 2013
          • 707
          i see a few bulged/leaking caps
          i circled the ones in red that are bulged
          but i would replace all of the ones i circled
          the one i circled in green im not sure if that is a cap or not
          if it is i would replace it as well
          this is really a low cost repair
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Dang it I should have opened the images ! See the attachment I upload thats your fault right there !
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              #26
              You need to replace those capacitors and your tv should be fixed. What are their values ?
              • jose6326
                • May 2013
                • 707
                this kit should fix your problem
                i normally purchase from digikey but i dont know if they ship to your neck of the woods
                http://www.ebay.com/itm/LG-50PC55-PO...vzWyvvga0Mfvpg
                • mojo7676
                  Mojo7676
                  • Nov 2015
                  • 19
                  • uk
                  #28
                  Sorry for thedelay. Received the part ordered through asleep on eBay. Looks suspiciously straightforward..l will try tomorrow to swap out capacitors and report back. Thanks again to all.
                  • mojo7676
                    Mojo7676
                    • Nov 2015
                    • 19
                    • uk
                    #29
                    "A seller" not "asleep"... Autocorrect
                    • mojo7676
                      Mojo7676
                      • Nov 2015
                      • 19
                      • uk
                      #30
                      update: good news... bad news... good news... bad news.... good/weird news
                      good news: replaced the caps as instructed. seemed straight forward enough
                      bad news: forgot one screw on the board.
                      good news: the tv worked.
                      bad news: 10 minutes later, 3 very loud pops (and much hysterical screaming from the direction of my wife and our 2 daughters) - a second between each pop, maybe. tv switched itself off but red light still on.
                      good/weird news: hit the power button the remote... and the tv came back on. it's been on for about 15 minutes now, no pops or anything.
                      so: any ideas? i imagine the worse thing can happen, if left running as is, is for the whole tv to become knackered completely. am going to switch it off but leave it running for a while tomorrow and see what happens. if you think this is dangerous, let me know.
                      thanks again for all the advice.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        #31
                        maybe as you have replaced the capacitors there maybe a little too much flux left on the board if you did not clean if afterwards, some solder ive noticed leaves a lot and maybe the flux allowed it to ark over the tracks hence the popping noise maybe worth a check.
                        • jose6326
                          • May 2013
                          • 707
                          i would remove the back cover again and check the caps
                          did you replace the new caps in the correct through holes?
                          meaning you might have reversed the polarities
                          • mojo7676
                            Mojo7676
                            • Nov 2015
                            • 19
                            • uk
                            #33
                            well, tbh, didn't even think about polarity (rank amateur, i know... appalling!) but... it's been fine since. if it is an issue, i guess i'll find out in due course... anyway, thanks again to all - especially reeceyburger and jose for being so helpful throughout.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              #34
                              maybe worth taking the back of and checking the polarity of the capacitors as it could/maybe be a fire hazard i guess.
                              • mojo7676
                                Mojo7676
                                • Nov 2015
                                • 19
                                • uk
                                #35
                                okay will do - didn't realise the dashes on one side were indicators of polarity. thanks again
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  #36
                                  yes thats the negative side of the capacitor theres usually a marking of some kind on the circuit board too look at one of the capacitors you have not changed you should see what i mean
                                  • mojo7676
                                    Mojo7676
                                    • Nov 2015
                                    • 19
                                    • uk
                                    #37
                                    sorry for the delay -
                                    anyway, another minor/uneventful update...
                                    the tv seems to be still working fine. go figure. again, thanks to all
                                    all best wishes for the new year
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      #38
                                      I would suggest you check it asap ! You could have an arching issue (due to lose screw) or something else which could damage the tv even further.
                                      • mojo7676
                                        Mojo7676
                                        • Nov 2015
                                        • 19
                                        • uk
                                        #39
                                        okay - i did that today and couldn't really see anything loose or crappy in terms of excess solder. i didn't go as far as taking out the caps to see if they were in the right way round. put it back together and it still seems to be ok. thanks again, reeceyburger
                                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:20 PM
                                        • Jaime Morillo
                                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                          by Jaime Morillo
                                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                          The TV was stuck on the logo and I couldn't access the update menu.
                                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                          The image result was good, but the image is inverted.
                                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                          08-18-2025, 11:38 AM
                                        • piershs
                                          Toshiba plasma 50WP16 wierd double image fault
                                          by piershs
                                          My 2001 Toshiba 50WP16 50" plasma TV has, after 20 years of trouble-free service, developed a wierd fault in the last 14 days during normal viewing - with no loud bang or smoke or any other excitement.
                                          Every 15-30 secs the right hand half of the image has a "glitch" for about 1 second before reverting to normal. The glitch has two forms and also depends on the aspect ratio setting (see photos):
                                          • 16:9 either a) a visible seam between LHS and RHS of impage or b) LHS image duplicated on RHS (photos 16x9)
                                          • 4x3 either a) no image on RHS or b) RHS image offset by 1/6th
                                          08-01-2020, 01:07 PM
                                          HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          09-06-2024, 10:56 AM
                                          HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook 1000 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load & Asset Tag boardview and 1050 G1 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
