LG 50PC55 Plasma–multiple attempts to turn on; but now no image... help
  • mojo7676
    Mojo7676
    • Nov 2015
    • 19
    • uk
    Newbie to the forum and fairly inexperienced when it comes to TVs – I don't have a digital multimeter. Apologies if this post seems long, but I hope the details are useful. For at least the last couple of years, our LG 50pc55 has had a rather odd and annoying fault which we couldn't be bothered repairing. When you switched the TV on, after it had been off over night for example, it would take maybe 10-15 attempts to switch on either through the power button on the tv or the button on the remote control. Eventually it would come and all would be well. If you switched it off then switched it back on, it would come on again immediately. If you switched it off and left it for an hour, then it would take maybe 3-5 attempts to come on. Sound and picture were always fine when it was on. However, a couple of days ago, this stopped. All we have now is sound but no images. I've done a few trawls and I think it might be the Y-Sus board (read Tom66s helpful guide) but I can't be sure given the earlier problem with the multiple attempts to switch on problem. I removed the back to identify the part number (EBR36223601/EAX34151501) and can get a replacement board for around 30 quid but it might be something else, like the Y-buffer/s or power board, that needs replacing. Any ideas/comments highly appreciated. Thanks in advance.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG 50PC55 Plasma–multiple attempts to turn on; but now no image... help
    Doesn't sound like Ysus fault to me, normally if you had a Ysus fail the issue would be fixed not intermittent. Do you have a hair driyer this can help you diagnose things ?
    • mojo7676
      Mojo7676
      • Nov 2015
      • 19
      • uk
      Yes I can get hold of a hairdryer.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Ok, power the tv on from cold. Then start heating the Mainboard with a hair dryer see if the tv starts faster. If it doesn't start heating the Psu then the control board. I have seen the Mainboards on Lg plasmas cause this symptom here is a link to my video of a similar one that I had:
        https://m.youtube.com/watch?v=66SeSEFVc-8
        • mojo7676
          Mojo7676
          • Nov 2015
          • 19
          • uk
          Ok will do. Mainboard is the middle one, right? PSU and control board along bottom? Thanks
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            The Mainboard has all your Hdmi input and other I/O ports.
            The control board is normally in the middle of the tv and has lots of white ribbon cables coming out of it going to the Ysus, Zsus and address buffers at the bottom of the screen.
            The Psu has the mains Ac plug going to it and is normally is in the centre at the top of the tv.
            Here is an example:
            • mojo7676
              Mojo7676
              • Nov 2015
              • 19
              • uk
              Great that's really helpful. Will try this evening n see what happens then report back. Thanks again
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                No worries keep us updated
                • mojo7676
                  Mojo7676
                  • Nov 2015
                  • 19
                  • uk
                  Ok will do. Just one point... It's not an intermittent fault as such. Even when there was sound n image, it wouldn't ever turn itself off or exhibit any other problems. To me it was as if it needed to warm up abd then itd be okay and stay switched on. A bit like some cars I've had that take a while to start but once they get going they're fine
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Thats an intermittent fault lol known as intermittent start up
                    • mojo7676
                      Mojo7676
                      • Nov 2015
                      • 19
                      • uk
                      Fair enough... Will be on with it in next half hour or so. Tbc...
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Ok mate.
                        • mojo7676
                          Mojo7676
                          • Nov 2015
                          • 19
                          • uk
                          So ok... Heated main board for a minute or so and then got a few clicks. Then heated the power board and within 30 seconds... TV came on with video. Am assuming then that this means one of these two boards are knocked but how do I know which one? Maybe I'll do it again tomorrow and see what happens when I heat the power board first. Or something else?
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Ok good stuff thats progress Now turn it off let it cool and repeat the same test on the Psu first let us know what happens.
                            • mojo7676
                              Mojo7676
                              • Nov 2015
                              • 19
                              • uk
                              Ok will do... But might be Tuesday before I can get to it next. Thanks again
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                No worries glad to help
                                • mojo7676
                                  Mojo7676
                                  • Nov 2015
                                  • 19
                                  • uk
                                  After getting it to work a couple of days ago, I fitted the back panel and mounted the tv on the wall. Tried the tv yesterday. It had been switched off over night and, as expected, no luck. I didn't have the time to take it off yesterday... but instead i just switched on the hair drier and left it blowing at the back panel from the top of the tv. Within a couple of minutes, it started working. Left it off last night and when i get home tonight, i'll take it off the wall and try to warm the power board but will start at one end and try to warm in a grid like fashion in case that can help pinpoint any specific element/component which might be replaceable. Will try to update tonight if i can or tomorrow at latest. thanks again.
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    Probably a bad start up capacitor, do you know what a capacitor is ?
                                    • freakaftr8
                                      • Oct 2012
                                      • 3743
                                      Yes it does sound like a bad start up capacitor, also have you checked for any broken solder connections or bad solder connections on the power supply? When your heating the board it has a tendency to flex and make contact where it is not usually making contact cold
                                      • mojo7676
                                        Mojo7676
                                        • Nov 2015
                                        • 19
                                        • uk
                                        Not 100% about capacitors - usually cylindrical? - but I'll take some photos of the board tonight and await further input... Thanks again
                                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:20 PM
                                        • Jaime Morillo
                                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                          by Jaime Morillo
                                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                          The TV was stuck on the logo and I couldn't access the update menu.
                                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                          The image result was good, but the image is inverted.
                                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                          08-18-2025, 11:38 AM
                                        • piershs
                                          Toshiba plasma 50WP16 wierd double image fault
                                          by piershs
                                          My 2001 Toshiba 50WP16 50" plasma TV has, after 20 years of trouble-free service, developed a wierd fault in the last 14 days during normal viewing - with no loud bang or smoke or any other excitement.
                                          Every 15-30 secs the right hand half of the image has a "glitch" for about 1 second before reverting to normal. The glitch has two forms and also depends on the aspect ratio setting (see photos):
                                          • 16:9 either a) a visible seam between LHS and RHS of impage or b) LHS image duplicated on RHS (photos 16x9)
                                          • 4x3 either a) no image on RHS or b) RHS image offset by 1/6th
                                          08-01-2020, 01:07 PM
                                        • Delired73
                                          TV LG 50PA4500 Plasma : bad image noisy
                                          by Delired73
                                          I have an issue and didn't find any solution by myself or on every forum about my LG plasma TV 50PA4500.
                                          Originaly the TV stopped to work and didn't want to turn ON again.
                                          After visual inspection, few transistors were broken, I tried to change them but some burned again, so I ordered on full new board. So, I changed the Yboard which was burned by a new one
                                          It now turns ON and the image and sound are present. But the image is very noisy and only visible when the room is in the dark.
                                          I check Vs and Va voltages...
                                          04-04-2021, 09:13 AM
                                          HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          09-06-2024, 10:56 AM
