Sony Bravia 55ex710 picture problem
  • Rufus5
    • Apr 2015
    • 6
    A friend asked me to take a look at this tv and see if it could be fixed. He said the screen would be jumpy and doubled when it turned on and would clear up after a while. The while got longer and it no longer clears up. I attached a picture of the screen, although it doesn't show how it flickers and jumps. I checked as best as I could and didn't see anything obvious on any of the boards. I unplugged and reseated all the cables, as well as put pressure on the frame for the tabs and nothing made any difference. I thought it might be the mainboard and tried to find a replacement, but I can not find one yet.
    Most of the mainboard is very small smd's and I am unsure how to test these and thought it was just easier to replace the board. Since that is not the case, with the board being unavailable, I was hoping to get some advice from this forum as to any possibilities of what else I could do. I am able to test with a multi-meter (but still learning) and can solder and desolder fairly well. I am concerned about the large area in the upper right side. Could this be a panel issue? Any help would be appreciated.
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Sony Bravia 55ex710 picture problem
    That's interesting. . Never seen one quite like that. I'm tempted to say panel ot tcon. Leaning more towards panel problem
    • Rufus5
      • Apr 2015
      • 6
      When I first turned it on today, the right side was duplicated on the left side, but down the screen further. Could a panel problem do that?
      • MisterD
        • Oct 2012
        • 668
        Try twisting the panel by grabbing the corners, also use a hair dryer in the tab bond areas, search this forum and YouTube for tab bond issues, I hope this helps.
        • Rufus5
          • Apr 2015
          • 6
          I tried twisting the screen and the hair dryer on the tabs, made no difference. I did try putting the hair dryer on the t-con board and most of the screen cleared up. It still flickered, but much less. I tried taking the cables off each side of the t-con to get it to make a difference and then tried to put the left one into the right side and then the other side. When I did this I had to remove the t-con from the panel and after this the screen went blank and I can't seem to get it to come back on. I assume I must have shorted something, but I can't seem to find it. I tried checking all the fuses on each board and they all seemed to check out good. Any suggestions as to what I could check?
          • freakaftr8
            • Oct 2012
            • 3743
            Well now you may have damaged the panel. This is a no-no as the FRP ribbons drive the opposite sides on each side of the panel so essentially you just applied 12 volts into a section that doesn't require it. You could try atcon and cross your fingers but I believe you did panel damage
            • pushbutton
              • Nov 2015
              • 3
              looks like you damaged the t-con board it's not the first time someone made a boo boo i've done loads
              • retrorepair
                SONY KDL-40P3600 Picture Problem
                by retrorepair
                Hello gurus, hope you can assist me...
                I have a Sony KDL.40P3600, with an issue on the left side of the screen (pictures attached).
                I think the problem is the panel, but before send it to trash, i would like to get a second opinion.
                Thanks in advance.
                10-11-2024, 05:12 PM
              • Spc.
                Sony Bravia KD43XF7596BAEP - Android no picture
                by Spc.
                Greetings everyone.
                I also have Sony Bravia, model:
                Sony Bravia KD43XF7596BAEP - Android.
                What happend is that image dissapeared while we were watching tv.
                Diagnostics:
                1. TV turns on, no errors
                2. Backlight turs on, no errors
                3. Power indicator turns on, white color, no errors
                4. Menu works on android, you can hear sound while switching channels
                5. Volume up and down works via TV remote and via buttons
                6. Tunner works, HEVC / MPEG-4 decoder works
                7. I get audio from channels
                8. No picture is present,...
                05-19-2022, 04:28 AM
              • KYBOSH
                Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
                by KYBOSH
                Previous owner said TV just went blank one day.
                They attempted to open the back panel and yanked the power connector off the power supply in the meantime.
                Easily fixed that and got the TV to turn on. Backlights come one with everything connected. Good Sign.
                The mainboard shows signs of life (red light on digital audio out is on) but that's about it. Good Sign.
                There is not blinking LED and the most importantly there is LED response and sound when I press the MENU button on remote control. GREAT Sign.
                I just downloaded the Sony KD-75X7800F Service Manual and...
                11-19-2024, 10:12 AM
              • lmcancu
                Sony Bravia 65x900F BL On but not picture
                by lmcancu
                I was watching youtube yesterday, when I paused it to go to the washroom. When I came back, the right side of the screen was showing half of the youtube channel and the left was black. I powered off/on the unit with the remote and now I have no picture whatsoever except for the bluish backlight. I did the factory reset (power + vol down), and now I when I power on I get the startup music, backlight but no picture.
                I took the back cover off, and reseated all cables but unfortunately same issue. I took some voltage measurements on the main 2 headers from the power supply board and...
                10-30-2023, 07:01 PM
              • jason123
                Sony Bravia KD-65X85J No Sign Of life (No BL, Picture, Front LED,..)
                by jason123
                Hi Folks,
                I have a 65" newer (2021 model) that has no sign of life. No backlight, no front LED (assuming it has one) and no audio or turn on chime.
                Photos below of the system
                The CN6401 Connector has the following vitals:
                STBY_3.3V is 3.432 V
                BL_ON low (0.153 V)
                BL_ERR low (0.051V)
                POWER_ON 3.42 V (as soon as I plug it into the wall this comes on)
                REG12V pins 12.7 V
                TCON_VCC12V pins low (0.11V)
                TCON_ON low (0.155)
                Large caps are at 392V as soon as I plug into power
                Seems like a Mainboard...
                09-08-2024, 07:05 PM
