Samsung UA60D8000 Cycling On/OFF
  • PHELLY
    • May 2015
    • 15
    Re: Samsung UA60D8000 Cycling On/OFF
    Thanks budm, I understand what you have explained. I really appreciate your help.
    • stjeff0
      • Jul 2015
      • 11
      We are working on this tv (Samsung UA60D8000) currently, and noticed we couldn't force the backlight on. Since the power supply is just clicking we were trying to isolate the problem, and found even when we forced the back light the capacitors never really charged going to the leds. We replaced the FETs at Q9201. It worked perfect !!!
      • PHELLY
        • May 2015
        • 15
        Thanks stjeff0, the TV is not with me any longer but I assume the FETs are on the power supply board?, if so, I had replaced the power supply board and in my case it did not fix the issue.
          09-07-2024, 05:50 AM
        • Asraf Atb
          by Asraf Atb
          01-27-2025, 05:02 PM
        • Kingfreddie
          LED problem on samsung UE55F6475, 2 strips work. The rest is flashing every second.
          by Kingfreddie
          Ok.. this is the story:
          Have an old Samsung LED 3D TV (UE55F6475). First it started to lose light on the lower 40% of the screen now and then. Like for 10-60 mins and then it would work again. Then a bit later it just got stuck in that position. The lower 40% of the screen is dark, and it gets progressively darker the lower u go so it's obviously that LED strips where not working. I also looked for similar errors online and saw an exact copy and on that one it was faulty LED strips.
          This is kinda how it looked, just that mine were at the bottom of the screen:
          09-11-2021, 01:57 AM
        • JSin21
          Compatibility of main boards between different variations of samsung MU6100
          by JSin21
          Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
          I have Samsung Smart TV UA65MU6100WXXY version DA01
          Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
          11-27-2023, 04:54 AM
        • mrautom8
          Samsung TV UN75H6350AFXZC main board schematics?
          by mrautom8
          Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
          Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
          While relay is on, all voltage rails are present and steady (scoped) on main board.
          I love a good logic puzzle but getting lost without any schematics.
          No shorts on ANY capacitor main board.
          Thermal camera shows 3.3V inductor getting warm instantly but...
          10-19-2025, 06:32 PM
