Samsung LN22B360C8D doesn't turn on
  • ruben53
    • Sep 2015
    • 37
    This is a Samsung LN22B360C8D with Power supply BN440302A and the main
    Board is BN41-01254A.It has the red light on but when trying to turn it on the
    red light goe's off and blink twice and the stay on but the tv doesn't turn on.
    The voltages at the output for the main board (board disconnected) are:
    Pin B-Dim---0v
    Pin 14v------fluctuate from 13.99v to 14.32
    Pim 5.1v----5.02v (there are 2 pins with same voltage)
    Pin NC-------0v
    Pin on/off---0v
    With board connected voltages are:
    Pin B-Dim--0v
    Pin 14v-----15.2v
    Pin 5.1v----5.08v (both pins)
    Pin NC------0v
    Pin on/off---0v
    On the Big Capacitor C105= 173.3v
    Ic PC 101= a)46.5v b)3.57v (pins on the cold side)
    c).2v d) 0v (pins on the hot side)
    D101= a)0v b)85v c)83v d)173v
    Please somebody tell me what to do now to fix my grandsons tv.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Samsung LN22B360C8D doesn't turn on
    Those are excellent clear focused pictures. So many people who come here looking for help can't understand the importance of this.
    The red light is your standby light indicating 5V standby is likely good.
    Pin on/off---0v
    Pin on/off---0v
    The last pin, on/off, is likely the command from the main board to tell the TV to turn on the backlights. It should be high or greater than 3V.
    If your multimeter has min/max, see if on/off temporarily spikes at 3V and then drops to 0v.
    In addition, if you hookup a DVD player, do you get sound? Can you see a picture if you shine a flashlight on the LCD screen?
    --- begin sig file ---
    --- end sig file ---
    • retiredcaps
      • Apr 2010
      • 9271
      44MB Service manual at (in zipped format)
      http://elektrotanya.com/samsung_ln19.../download.html
      Your browser might take up to 1 minute saying "processing" until "Get Manual" shows up.
        Never mind, I miss read the info.
        • retiredcaps
          • Apr 2010
          • 9271
          Originally posted by budm
          How about the Voltages for the ON/OFF, B DIM, and the rest are when the all the connectors are back in place?
          Hi budm,
          The voltages with the board connected are listed in post #1.
            Ahh, sorry I missed that. So basically main board problem.
            • retiredcaps
              • Apr 2010
              • 9271
              With your surgery, I'm surprised you are so active. You probably missed it because you are tired.
              Anyway, glad to see you back, but take care of yourself first.
              • ruben53
                • Sep 2015
                • 37
                Thanks a lot for trying to help me.
                When I hit the power the voltage on pin on/off spikes to .06v and then drops
                to 0v.
                Does that means that the problem is in the main board?
                The original problem was that the stand by light was blinking and somebody told me the problem was the main board so I bought this board and installed it and now the stand by light stays steady on but the tv doesn't turn on.
                • ruben53
                  • Sep 2015
                  • 37
                  to 0v.
                  Help,is there somebody else that can help me?
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    was the main board a exact match as in all numbers on white stickers etc match 100% can you retake all the voltages again with the new mainboard in too.
                    • ruben53
                      • Sep 2015
                      • 37
                      Thanks for answering.
                      Yes the replacement board has the same numbers is an exact match.
                      The voltages that I posted are with the new mainboard.
                      I want to be sure the problem is in the mainboard so that I can return it to the
                      seller,the problem is that seller doesn't have another mainboard to replace this one.
                      • ruben53
                        • Sep 2015
                        • 37
                        Hellow,can somebody tell me if there is a fix for this problem?
                        • ruben53
                          • Sep 2015
                          • 37
                          This is an update,when I take off the plug that goes from main board to the
                          T-con board and hit the power the screen turns on but with the T-con plugged
                          in the screen doesn't turn on.
                          Does the T-con board and the screen panel is one piece or it can be replaced
                          apart?
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            does should like the panel or tcon has a short can you upload pictures of the tcon and back of panel so we can see what were dealing with as some of these smaller sets the tcons cant be removed as are part of the lcd screen assembly.
                            • ruben53
                              • Sep 2015
                              • 37
                              Here is the picture of the back of tv.The T-con board looks that is part of the screen.
                              Can this T-con board be fixed?
                              Iam sorry for the picture isn't complete,I will try again.
                              • ruben53
                                • Sep 2015
                                • 37
                                Here is another picture,hope this one is OK.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  yes thats fixed to the lcd so cant replaced, im not sure what else to suggest you too test maybe wait until a more experienced member chimes in with ideas
                                  • ruben53
                                    • Sep 2015
                                    • 37
                                    OK, Thanks.Lets see if somebody else can give any idea,because this panel is
                                    not easy to find a replacement.
                                    • pajdek
                                      Lenovo Y700-17ISK turn on and off
                                      by pajdek
                                      Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                      09-20-2023, 02:49 AM
                                    • valvashon
                                      Samsung LS23PTNSF/ZA- Erratic behavior 20 minutes after turn on
                                      by valvashon
                                      This smaller Samsung TV will turn on fine and work fine at first. By this I mean that it will respond properly to the remote commands with channel up and down working and volume up and down working, etc.
                                      After the set has been on for a while- 20 to 30 minutes- it stops responding or responds erratically to commands from the remote or the front panel buttons. Remote is fine, works well with other TV's.
                                      My guess is caps in the power supply warming up and changing value leading to the erratic behavior. TV does not act erratically unless you try to change a channel or something like...
                                      06-16-2023, 01:22 PM
                                    • 99Cookies
                                      Samsung NP350V5C laptop wont turn on
                                      by 99Cookies
                                      I know there's a lot of threads regarding this particular model but none I can find on the web replicates my issue. The exact model of mine is: Samsung NP350V5C-S01CA
                                      I've been using this laptop for around 7 years before I put it aside. 2 years later, I tried to power it on and it simply wouldn't.
                                      When I press on the power button, the front power LED lit up but for around 4 seconds, then shuts down. Nothing else happens, no fans, no screen, no post and no light around the power button (which is different than the front power LED).
                                      08-12-2023, 04:38 PM
                                    • Bloopeta
                                      Samsung UE58TU7100K Wont Turn On
                                      by Bloopeta
                                      Samsung UE58TU7100K
                                      When trying to turn on, red light flashes twice, then pause, then flashes twice, then pause, then comes on solid, and screen lights up for a second (no image), then goes off and starts the cycle again.
                                      Is there any known faults that I should be aware of before opening it up?
                                      09-15-2022, 10:40 AM
                                    • Thefoursea
                                      samsung slow to turn on pn58b650s1fxza
                                      by Thefoursea
                                      takes 30 minutes to turn on then runs fine
                                      02-18-2023, 06:52 AM
