Vizio Main boards smart tv
  • ozzy214
    • Nov 2013
    • 319
    • usa
    Question, what causes the most failures on Vizio smart tvs? I had a 100 tvs come in. Mostly scrap or parts for online. A lot were Vizios and knackered. I had luck on a 22" razor before this load came in, where I changed u33 chip and it booted right. In fact that tv was only used 7x and was only a month old from walmart still under warranty.
    So why is there high failures and anything I can do to prevent it? I have fixed 2 of them since the mainboard were cheap...40 and under. But I'm leary about reselling if there will be future issues whether a month or year and the tv crashes.
    Im wondering if the eeprom is getting corrupt with updates over wifi and I should advise customers to use Ethernet versus wifi. But most peeps dont listen...lol.
    I still got a 46" ish Vizio I would love to fix, but main is 130 bones. And noone sells eeprom or anything for it....Also is there a way I can force it to update or check updates before it leaves? I couldnt find a way in the menu....
  • mrtek
    Vizio M65-C1
    by mrtek
    Hi.
    picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
    When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
    This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
    07-14-2025, 07:28 PM
  • Yanleb
    Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
    by Yanleb
    Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
    If they are not compatible why did Samsung give them the same part number to begin with?
    08-04-2025, 11:35 PM
  • ugamazing
    Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
    by ugamazing
    I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
    We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
    12-17-2024, 07:05 PM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • cheeky2
    by cheeky2
    05-25-2024, 03:27 AM
