Seiki SE32HY27 - How to change source input
  • jstiene
    • Feb 2013
    • 148
    Hello. I have a question hopefully someone can answer. I have a Seiki SE32HY27 that has a cracked screen. I am trying to verify if the HDMI ports work. In this case, pressing the source button doesnt help, most likely because the TV is starting up in a menu (that I cant see) This happens with various newer models. Is there a way that I change the input to HDMI other than pressing the source button? I believe some of the lower end models like this one do not auto detect the input upon power up? Am I correct in that assumption?
    Any help is greatly appreciated
  • ugamazing
    820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
    by ugamazing
    So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
    1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
    2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
    04-10-2024, 08:06 AM
  • matthewmcconaughey
    I need help with my friend Sony GDM-FW900 24” CRT
    by matthewmcconaughey
    Hello, Badcaps is my last resort. I am the first owner of the monitor. I reached almost every repair store in my area, but no one even wanted to hear about troubleshooting an old CRT monitor. At this point, I have been trying to figure it out by myself, but I have no idea where to start or look for.
    I wish to know how to think and locate a failing component. I will put all my efforts to learn and contribute.
    1. It started with a bright and greenish picture upon starting a cold monitor.
    2. About 2 years ago, only on the cold boot, the screen started to occasionally flash with
    05-16-2023, 03:15 PM
    Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
    The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
    The bq24745 features dynamic power management...
    10-23-2024, 02:50 AM
  • Lvsitano
    Asus X532FL 3.2V at source and gate
    by Lvsitano
    I am having some trouble with troubleshooting a Asus X532FL rev 2.0 motherboard, which does not power on. So at the first MOSFET, I am getting 19V at the drain, and then 3.2V on both gate and source (compared with ground). Of course, the 2nd MOSFET's source will have 3.2v at source.
    First MOSFET is a QM3056M6 and 2nd MOSFET is a QM0930M3
    I already checked first MOSFET and source and gate are not shorted (drain with source not shorted either). Also I have 1.7V at the LDO rail (measured at the keyboard connector, as the power button is on the keyboard).
    First...
    06-26-2024, 02:13 PM
  • eigma
    Samsung UN40H5003 boot loop every ~8 seconds
    by eigma
    Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
    Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
    SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
    Main board: BN94-07592P / BN97-08922R...
    11-20-2024, 10:31 PM
