Samsung UE46D5005 2x5 red blink, no picture
  • cptCory
    • Oct 2015
    • 17
    • Norway
    Re: Samsung UE46D5005 2x5 red blink, no picture
    Great news!
    I managed to fix my samsung permanently after years of glitching out giving the earlier mentioned error, then it would work again after voltage probing around the PFC without a real insight into why it fixed the problem. Anyway, it usually worked for a few days before the procedure had to be repeated.
    I fixed this permanently by resoldering a broken wire in the PFC where it is bent 90 degrees before going into one of the coils. The wire was so worn it would sometimes be open circuit and give the error blinking. Then by touching the PFC it would close the circuit again and work for a short while. After locating the culprit wire with continuity check of all the pfc wires I stripped away the insulation in the problem area and applied som solder to it. It's been working for a year soon without glitching and still beating. Yayyy!
    In case somebody else still has this old screen and encounter the same problem, this post was for you.
    • Ierwin
      by Ierwin
      05-13-2025, 03:31 PM
      09-07-2024, 05:50 AM
    • JJAAMM
      by JJAAMM
      Problem
      07-06-2023, 06:01 AM
    • stylishconsultant
      un60j620dafxza - Samsung No Display Problem
      by stylishconsultant
      Hi All,
      Need help.
      I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
      So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
      problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
      might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
      09-04-2024, 03:26 AM
    • Mgiffune
      by Mgiffune
      06-09-2024, 10:28 AM
